Has anyone here tried these types of loupes? If so, what magnification?
They’re selling on Amazon for around $300 CAD, just wondering if they are worth it?
@Barney It says 5.0x in the image.
That said you can find a healthy selection of affordable ones on evilbay. Just search for Dental Loupes.
Possibly I don’t need 5X magnification? That is why I was asking if anyone has real life experience with them? The magnification I generally use is 2X using these.
A recent dental hygienist visit has really inspired me to look into ergo loupes because of chronic neck and back pain I have. She is pregnant and is able (forces you) to keep proper posture. “Real” quality dental or medical loupes start at 5k (which I have no intentions of spending) is what she paid.
I would say no.
The field of vision is way too small for our type of work.
The ones in your post are probably the right thing for working on small areas
like jewellery or a single tooth.
Trying to work on a larger would probably make you dizzy.
I chose headband magnifiers. The one I bought had battery powered side mounted glow buld “head lights” which were totally worthless. Use good workplace lighting instead.
The ones sold now have lead lights but you still only have light straight ahead and the surroundings will be in relative darkness.
It also had a magnifier that could be swung in in front of one eye (the right I think) which was also a rather useless gimmick.
It had two magnification levels by folding down a second set of lenses inside the fixed one.
I currently use it without the swing in magnifier and the lights, the extra lenses dropped out which was just as well.
My current working method is to wear reading glasses (cheap stuff) under the headband magnifier,
when I need more magnification I switch to stronger reading glasses.
Flipping the hinged part of the headband magnifier up gives me normal reading magnification.
There are also magnifier lenses that can be clipped onto normal reading glasses but they add extra weight to the reading glasses, supporting the weight with a headband is more comfortable.
You may be right about focal length @ 5X where it may be too condensed.
I also have to wear prescription glasses under my headband, which is also added pressure to the bridge of my nose. I know, I’m a bag of hammers with my issues…lol
Go for headband magnifiers and use some modelling skills to attach cheap reading classes in front of the original lenses. Cheap readers go to +4 (at least) and that is more than enough given that you have prescription glasses.
This is what I use as well and all the above comments are spot on for me as well.
the evilbay Dental Loupes are typically 3.5x magnification so they may be a good sweet spot.
I have a headband like @Uncle-Heavy but I have been thinking of trying a set of loupes because the headband doesn’t really suit my needs. They are also really heavy.
I must be in good company - those are the very ones I use!
They come in different weight classes,
the cheeap ones I got weighs 85 grams (3 ounces) AFTER getting rid of the “head lights” (2 + 2 AAA batteries) the swing-in magnifier and the extra lens.
This one weighs 380 grams (but remove the lamp and
batteries …)
This one, a bit cheaper, is at 1.6 ounces (remove lamp & batteries 2 x AAA)
I have thought about that type of headband magnifier as well.
I guess my the only way I will know if would work is if I talk to an optometrist about them?
Can you use a normal old fashioned magnifying glass?
Reading glasses are just magnifiers and the headband thing is basically strong reading glasses mounted in a holder attached by ones head.
I think it will work if your prescription glasses restores your eyesight to “normal” vision.
I can wear the headband ones, etc. my problem is ergonomics. I want to correct my sitting posture to ease the chronic neck and back pain I have.
I suggest getting an office chair with a seat that can tilt forwards/backwards
and a removable back rest- Remove the back rest and let the seat tilt freely.
This forces you to sit upright, as if you were riding a horse.
There are also chairs designed to be used as if riding a horse
Just getting rid of the backrest and use a tiliting seat might be enough.
The next step is to figure out if your work surface is at the right height.
If you are bending your neck to do fine work then the workbench is probably to low.
Place books or something on your workbench, rest your elbows on the books and
keep adding height until something held in your hands can be worked on without
having to bend you neck. Then build a simple “spacer”, a board and some planks
or something.
Another possible cause of neck/upper back pain could be your pillow.
My wife had problems and then I used her pillow once and it was way too thick and firm.
Swapped it out for a thinner and softer pillow and most of the pains went away.
Neck pain caused by incorrect work position will go away when the ergonomics are corrected,
a bad pillow will hurt you ebery night.
I use these same magnifiers on top of my reading glasses. Gets a little uncomfortable after a time. Other than that…I’m good.
