Help with sanding cloths
My friend has a set of sanding cloths for working on his model car kits. There are about 10 different grits. He does not remember where he got them from on eBay. They are different colors and are about 8 by 10 inches in size. Tamiya makes some that are expensive per sheet. Does anyone make a complete set of all grits?
Not sure if this is what you are looking for:
Yes on the sanding sheets. However I would like a set that had one of each type in the set you get.
Micro Mesh
18 double-sided 5 x 5 cm pads - 2 of each class: 1500, 1800, 2400, 3200, 3600, 4000, 6000, 8000, 12000.
Sheets about 1/2 the size. Might be able to find at hobby lobby.
