Hm… Looking at the stern of the Trumpy kit’s hull, I think the Atlantic kit has captured the shape better there as well, when compared to the lines plan.
The Trumpy kit looks more bath tub like at the stern…
Of course I already have a bunch of aftermarket gear to go with the Trumpy kit too
I agree, above is the Trumpy Eskimo Sans Bow, below the Atlantic Models Tartar, I can’t show a direct comparison of the bow… I did fix the bow on the Trumpy kit I built as HMS Cossack a few years back, It was a pain, and good luck to you with that.
Hi, please ignore the “warm light grey” etc colour descriptions - those didn’t exist. They are based on badly age-damaged samples of linseed oil paints.
Some of the small stuff, The quad 2pdr pompom as per the photographs I have found clearly show a late war quad with splinter shielding, the railings were cut off, and splinter sheilds made form 10thou plastic strip.
The searchloght platform / after control position was from the etched fret with the searchlight and binacle with wheel from the Black Cat upgrade. A couple of support struts added from brass rod and some copper wire voice pipes.
The upper bridge, with black cat parts, stll needs the radar adding to the rangefinder tower, some voice pipes and a few other details. the bulwarks did look a little low compared with the hieght of a 1/350 figure, and the binacles. Some plastic strip was used to raise the slightly.
All the major components and the armament test fitted in place. A and Y guns have their shields in place to check fit. B & X gun I left open fro painting. Next job will be to mask up and spray the anit fouling, then some of the components such as the funnels, midships AA platform etc.
Paint starting to go on the superstructure parts. only the forward funnel and the midships AA platform are fixed down. Studying photographs,of the actual ship, both in books and on line the midships AA platform appears to be white, not light blue as per the painting guide. I may be wrong.
The camo on the rear of the bridge mostdefinetly needs tidying up. It may be tthe perspecive of the photograph, but the ladders look a bit too long. I have just solved that. I also have the etched fret for the Trumpy kit I have been tinkering with for over two years, building HMS Eskimo sans her bow after being torpeoded at the 2nd Battle of Narvik 13/04/40. I will gently pry those off and respray them and fit them to Eskimo, and then fit the correct parts.
I did notice the Trumpy hull also appeared to be a bit wider, I did think this might be an optical illusion as I had removed the bow to built it as HMS Eskimo 1940, 2nd Battle of Narvik, after the bow “fell off” after being hit a torpeo. The Atalntic Models kit came in at about 32mm = 11.2m, according to my references the beam was 11.13m, so pretty good, The Trumpy kit came in at about 36mm = 12.6m.
The Trumpy kit is ideal for the Eskimo sans bow build as it removes one problem. Having got the stalled project from the back of the bench, I am minded to push it on and try and build the base of her sat along side a little jetty in a small Fjord.
I am very much enjoying the build. The Black cat upgrade for the late Tribal is really adding a lot to the base kit, which is fundementally a good kit, and it would not be beyond the wit of man to add scratchbuilt details should they desire. (I can be a bit of a lazy modeller). I have just ordered the Early Tribal class set from Ben, not only because it is a good value fro money, but there are quite a few spare parts on it.
