How to best attach tracks to road wheels on Tamiya model tanks
Yes it will.
Sorry to ask again
But whats the best way to heat up the screwdriver pin anyways?
Actually that may not work as it looks like a soft plastic or hardened rubber next to the blade of the screwdriver. To heat up the blade, use a flame like on a gas stove. This will heat up the metal which you then press to the tracks but if the metal gets too hot it can melt the plastic or rubber bits on the screwdriver. Not hot enough and it won’t work.
To make this work, put the tracks together as if they were going on the tank (spiky bits to the inside). At one end of the tracks there will be what look like 4 little pins. Line them up then put them through the 4 little holes at the other end of the tracks (you may need to make the holes a little bigger).
Once the pins are through, heat up the screwdriver or thin metal object, and press it onto the plastic pins that you should be able to see coming through the holes. Use the heat to gently squash the ends of the plastic pins. This should ensure the two ends of the track don’t come apart.
Dan, seperti selalu; kalau ada pertanyaan silahkan tanyakan saja!
Burning Candle Gif
The soot from the flame will coat the screwdriver blade and
“lubricate” it which helps preventing melted track material from
sticking to the screwdriver. Start by heating a little, test if it is
hot enough, heat a little more if needed, test again and repeat
until the screwdriver is hot enough.
How to tell if its hot enough?
When the screwdriver softens the little peg on the track and it forms into a rivet head.
The tip of the screwdriver will change color, usually to a blue-ish silver. Get it to where you think it may be hot, try it and if it’s not hot enough, no harm done, heat it some more and try again.
Okay got everything ready
Now how to put the wheels and tracks together without anything snapping?
Edit: put on the tracks and the tank is finished
