Idf 78
Great build, Jonathan. Nice to see a clean faded look.
Congrats on finishing! :slight_smile:
Great looking result :+1::+1:
Managed to get primer on my Nagmachon, I used a 50/50 mix of green and black VMS primer, just because I wanted something diffrent..
I think you’ve got “something different” covered… :grin:
Thanks, but it will be covered with IDF grey… :wink:
And now most of it is covered in IDF grey..
I used these colours (the last two were used to lighten up the base colour)
Next step…
And this should be enough for what will be visible of the tracks… :thinking:
I pulled my stuff for the Magach out of the boxes and looked at it…
I even got a resin loaded turret basket off eBay since the Legends basket is made up of PE, brass rod and hope.
My plan (laugh here) is to start next week.
Forgot to take photos as I worked thru this build but I have it primed.
Time to do some work on this one again…
Scratches, shadows and highlighted bolts…
Used some metalics on tracks, idlers and sprockets…
And the used the same metalics on the dozer…
Painted grips in red, used canvas tone on the smokegrenade covers, leather for water canister straps…
Put the wheels on, added the tracks and the side plates, placed the decals, got the upper structure on added the screens… and played with some AK dry ground and some VMS pigments…
Nearly there…
Added the chains…
Made a crew…
Forgive me if it’s in an earlier post but whose figs? I like the poses.
This set, I just turned their heads so they would be looking to the side, thought it looked nicer than ‘just boring’ straight ahead :wink:
Excellent work!
:+1:
Well heck, I’ve got them in the stack.
More work done… added pinwash, dirt, grime, steel pigments(also on the welding seems), rust, soot, grease, clear green…
And busy with the crew..
Amazing realism. My hats off to you. Well done.
Great work as always, Bert!
