Hello, colleagues.
The process of making photo etching with their own hands, in this video, disclosed - completely. Come in, see, subscribe well and you can donate.
You can choose subtitles in the following languages: Arabic, Portuguese, Bulgarian, Croatian, Czech, Danish, English, Finnish, Dutch, French, German, Greek, Hungarian, Italian, Japanese, Korean, Chinese (China, Singapore, Taiwan, Hong Kong), Norwegian, Polish, Romanian, Slovak, Slovenian, Turkish, Spanish, Swedish and Serbian.
A small addition to the last video.
When making a layout (“CorelDRAW” or “Adobe Illustrator”), you need to provide a frame in which the details will be inscribed, and these same details need to connect jumpers between themselves and the frame, and jumpers to draw only on the back of the layout. The frame is 2 mm wide and bridges 0.5 mm. It is easier to control the etching process and you will not have to assemble the ready product in a scattered manner. Transparency agent is more suitable in the ratio of 1 g., of caustic soda per 100 ml., of hydrogen peroxide. Manual of photoresist says that development process should not last more than 1 minute. Etching solution - too much chemicals, you can safely divide them in half of the amount stated in the video, and maybe a little more than 50%. Etching should take place without rapid boiling, slow of course, but will be of higher quality. I don’t seem to have forgotten anything.
Long Live Heroes.
Hello.
The way you can reduce the diameter of copper wire, with a simple tool, in this video. Come in, watch and subscribe.
When stretching the wire are you pulling from both sides or only one side?
Yes, you have to pull from both sides, evenly.
While different material, I have found better results with plastic securing one side and pull only in one direction give a more consistent stretched material. Have you tried?
No, I haven’t, I’ll have to experiment.
We are launching a new section (playlist) called: “Putting together a model”. Let’s start with a copy of the lightweight Soviet T-26 tank at a scale of 1:35, from the manufacturer “Hobby Boss”. Before assembly - overview of the model, look at the box, see what’s in the box and attach parts to the drawings.
Come in, have a look, subscribe.
I like the comparison to the plans. Looking forward to the actual build.
Thank you, I’ll try not to drag it out too long.
Wire cutters - it’s hard to imagine modelling without this tool. Let’s take a look at the update and improve their cutting qualities. In the video there is not only testing, but also “crash test”.
Hello.
The new video is devoted to one useful tool called a jewellery jigsaw. We will consider the design, tooling to it, saws and technique of work.
Visit the channel, put likes and subscribe.
Good afternoon.
We continue to work on the model of light, Soviet tank, T-26, in scale 1/35, “Hobby Boss”. Determined inaccuracies made by the manufacturer, which we begin to eliminate.
Visit the channel, put likes and subscribe. Thank you.
Hello.
We compare solvents - pinene and white spirit, for art works. We make our own flush from oil paints, make a comparison, experiment.
Hello.
A model of a WWI fighter plane, “Albtros D.III”, scale 1/32, manufacturer “Roden”. Let’s look at the box, look inside the box, examine the contents of the box, attach parts to the drawings.
Visit the channel, watch the video, put likes and subscribe.
Thank you.
Greetings, colleagues.
We continue to work on the model of the Soviet light tank “T-26”, namely - to bring it in line with the model of 1935.
Visit the channel, subscribe, put likes.
Thank you.
Growing a metal tree.
Looking forward to part 2.
In the new video, we will start assembling the model “Albatros D.III”, in scale 1/32. We will start with correction of basic geometrical inaccuracies. We will apply the details of the model to the drawing and in some cases we will increase polystyrene, and in some cases we will remove the excess. We will use tools: jigsaw, files, files, files, scraper and others, as well as epoxy “Milliput”.
Visit the channel, watch the video, subscribe, put likes.
Thank you.
You can choose subtitles in the following languages: Arabic, Portuguese,Bulgarian, Croatian, Czech, Danish, English, Finnish, Dutch, French,German, Greek, Hungarian, Italian, Japanese, Korean, Chinese (China,Singapore, Taiwan, Hong Kong), Norwegian, Polish, Romanian, Slovak,Slovenian, Turkish, Spanish, Swedish and Serbian.
