I just received 2 sets of the Late M1078 conversion sets i opened both sets to inspect bot sets and noticed one is under size has anyone had that issue with legend stuff see attched pic
fiirst pic is the original grill
second pic is the under size part
the 3rd pic id a bit closer last pic is a bit closer has anyone had issues with inconsistency with legend stuff?
It shrinks?
My second Seinfeld reference today.
There were times in the past when there were some shrinkage issues. Lee will make it right.
so contact legend directly?
i just sent legend a email
I would like the armored version with the doors opening front to back.
Like this, the LTAS cab…
Available as a 3D printed item from our own @MikeyBugs.
looks good Mikey id love to add that cab to my M1078 and M1083 builds but the the clear plastic scares me a bit
They were easy to replace w/clear sheet styrene. I just traced around the 3D printed parts w/a sharpie, then cut them out w/a pair of scissors. A little trimming here and there and they fit right into the window openings on the cab. No issues at all.
Apparently the clear resin I use is also… Let’s say… Not good… I’m going to try to find a better quality clear resin that will hopefully stay, you know, clear but that could take a while.
