hi
it has been seen on face book and they are awaiting metal barrels when I last asked and mantel covers
ossie
Good news then.
One question re the road wheels. A few years back there was discussion on the ribbing in Centurion road wheels and how they differed over time. This is an image I saved for reference.
I assume when the AVRE were first built they would have been fitted with the ‘First type’ of road wheels. Would they have been replaced by others over time?
I am considering adding the central rib to a set of Firestorm tyres I have. These are meant to replace the kit’s vinyl ones:
Based on 9mm x 9 mm on the ‘second type’ that is 0.010 inch at 1/35th scale but Evergreen only does 0.010 x 0.020. However, if they were fitted with the ‘Third type’, I could probably get away with that size strip. Yes, it will be a little work to fit the strip but being a separate ring, it is easier than adding to a solid wheel and tyre.
To be honest never bothered about that as long as it had three ridges.
Why we could have had all types to be honest . When I was in our centurions AVRE along with BARV and ARV were only cent users .
Also probably been remade which they tend to do with some good rims.
Ossie
Hi Ossie
Nice pics.
Perhaps you’d know the answers to a couple of questions I have - What was the job of the 5th crew member?
How many rounds of 165mm were carried, given the 5th crew member occupied the space where many of the standard gun tanks rounds were stowed?
Mal
Thank you so much for these explanations. I already have the Amusing Hobby kit in the stash. I’ll try to fix as many flaws as I can.
However I fear the idlers are the biggest issue.
Olivier
Hi Mal
The 5th crew member would be a Combat Engineer Class 1 but in reality it was a another driver /wireless operator .
in gulf war no co driver as it was used for stores .
so one was stowed in co drivers , three around turret basket ,
some under gunners seat and rest in the floor
see pictures and here a picture of a breech as well.
round weighs 63 lb in Gulf war they used same ammo as M728 CEV
some pages out of user handbook , my 1/25 scale plans and some pictures showing floor when you lit access plate up on turntable floor .
Oliver
Accurate Armour for front track adjust wheels
Ossie
Mal
number of rounds stowed is 30 . in gulf war AVRE trailer was also used to stow them
unofficially
ossie
Thank you again for the tip.
Olivier
OK, I don’t know how much help this is as it is not a great photo and the tank has a tarp on it, but here is a shot of an AVRE in action on the back of a truck during the Gulf War.
Thanks Ossie
Most useful
Mal
I was going to say, 5th man was usually a Wally Op - I was 77 AES from 1991 to 1997. POM/Frog op.
Firestorm do another option for you to consider Olivier:
I can’t comment on accuracy but they look the part.
Peter
I used this reference on my Danish Cent a while ago. It looks good and the fit was easy on the AFV Club swing arm.
If I decide to change the idlers I’ll probably buy the AA one. Even after Brexit I guess I still can trade with a British company
AA idlers come with the swing arm and have been tested on the Amusing Hobby hull.
edit: I checked for the prices. AA and Firestorm are equivalent once you add the shipping. 20 euros are a bit pricey just for 2 wheels.
Olivier
hi great photo this was before they were up armoured and just as they arrived in teh gulf and moving up
Hi Khouli
I was armoured Driver W/O Centurion AVRE and bridge layers then chieftain AVLB 1974-1987 31 Onsubruck ,26 CAES munsterlager , Bovington then 73 Close support Osubruck.
OK! I didn’t know anything about the background of this, we just passed a British convoy on the road, and I snapped a couple photos.
…and those ‘surprise’ pics are the best pics to get…
Where is the socket for the headlight power cable when the add-on armor is fitted?
Olivier
hi olivier
believe it was the top set of sockets as there is quite a bit of room under the armour. but unsure as some crews rerooted the cable and added there own cabling .
ossie
