@18bravo, thanks for the photo. I am not at that stage yet. Just collecting references for when I get to that stage. I am only on the chassis right now.
I’ll see what I have. I have photos scattered all over the place that never made it into my walk arounds form quick visits looking at this or that that I never transferred from my phone. If I have time I’ll search it and my computer.
Thanks! Would you have any photos of where the M134 ammo can and battery are in the HMMWV as in this M1151? I plan to do this one as well.
No, but this is where my memory kicks in, Mounted on the floor, three in a row, side by side, with the feed end facing the rear of the vehicle.
Thanks again! So, something like this? I only have two LR ammo cans to show but will have to get the Legend ammo can set for the rest.
I would think it would be a similar setup for the M-ATV’s, maybe?
The Legend set includes three 3,000 round boxes and three 4,000 round boxes so one set should be good enough.
Been a few years. I think they were much farther forward.
This is a screenshot of the same RG-33 vehicle, where you can see where the ammo can is located.
In this vehicle the seat where the gunner controls the RWS has been removed and a metal plate/shelf has been added.
I have no photos of the battery, I guess it should be on the same plate/shelf.
Great screenshot! Thanks!
@18bravo, Found a video of an M1165 with an M134. In the photo below, you can see the rear is open. The ammo cans look to be in the rear cargo area. With the M1151 having the rear area closed off, the ammo cans would be in between the rear seats as you suggested.
This screenshot is of the same M1165. You can see the feed chute attached to one of the ammo cans to the right of the photo. He is standing on something raised with some kind of rubber mat on top of it.
This is also the same M1165 and you can see the outside walls of the cargo area in the rearview mirror.
Also just found another video but this time of a SOCOM M-ATV with M134. Unfortunately no good interior shots showing where the ammo cans are stored.
This is the best screenshot I could get showing the interior. You can see the right rear door, right rear seat with what looks like a couple AK’s on it and the feed chute but not where the ammo cans are located.
Great detective work !
It seems that in this vehicle was created a cage for a K9, very unique setup
@Seanmcandrews, thanks! I don’t think there is s raised area in that HMMWV. I think the rubber mat is just on top of the transmission hump.
@galactica, yes, there is a cage for a K9 at the rear right side. You can see the K9 in the second photo.
This is the video showing the M1165 with M134 and K9.
|https://www.youtube.com/watch?v=gyAaIKF6tSQ
Does anyone know why the RFM M1240A1 w/CROWS II kit RM5052 has two boxes on the rear bulkhead exterior? The instructions show to assemble two? Does anyone know what the second box is to the left is in pink shown on the second photo below.
On the other RFM M1240A1 w/RPG net and CROWS II kit RM-5145, it only has one of those boxes on the rear bulkhead exterior.
This photo shows different M-ATV’s with the two boxes.
Started attaching some of the PE.
I also scratch built the broken off and missing pieces from the seats.
Lots of resin to go in at a later time. They are the radios and other components for the the ceiling and some for the turret.
Got the Legend M134 ammo cans the other day.
The Legend ammo can, on the left is slightly different from the Live Resin ammo can. The Live Resin is also wider. These are the 4,000 round cans.
Here are the 3,000 round, on the right and 4,000 round on the left.
The interior parts are from the Panda M-ATV. The ILK SOCOM M-ATV interior is the same size. Definitely can’t fit 3 M134 minigun ammo cans across the platform on the M-ATV. The platform is not wide enough for three They can fit across as shown in the second photo. There would be no where for the gunner to stand though. These are the 3,000 round cans.
Here is one of the 3,000 round cans in between the two rear seats. The ammo can cannot fit behind the seats. The interior is only in primer and the seats are only dry fitted.
The 4,000 round ammo can is too big to fit between the seats.
I cropped much tighter of the photo of the SOCOM M-ATV showing the interior and it looks like there is definitely something in between the rear seats just behind his legs. If that is an ammo can, seems only one is in the cab. The others might be stored in the rear cargo area. The battery can be fitted under the platform he is standing on.
Got most of the second Panda M-ATV primed today but was interrupted by a thunderstorm that lasted roughly 3 hours. Still raining but lightly and supposed to rain into Saturday. I can only paint outside so nothing else getting primed until maybe Sunday. I was hoping to airbrush the base color Monday but the thunderstorm set me back.
Painted up some of the ProArt interior pieces the other day for the second Panda M-ATV.
Today I got the base color airbrushed before the thunderstorm but while airbrushing, the thunderstorm rolled in and we lost power so I had to stop. Luckily, I got most of the parts in the overall FS33446 before the power went out. The turret needs redoing as I painted it but forgot I was in the middle of modifying it to fit the M134 flexible ammo feed chute through the hole with the cover plate. I started drilling out the cover plate but didn’t finish so have to go back and do that.
It was too late to finish airbrushing everything once the power came back on so I started fixing up the interior. Is the cabin floor fully in sand? I can’t find any interior photos showing the floor.
The floor gets different treatment in the front and rear. I’ve sent you all the photos you need. Also, since I helped Pro Art with that set, I’ve also sent photos that should show where most everything goes.
