for my hypothetical M1A3 and i plan to cross breed a Rye Field M1A2 SEP v.2 with the Amusing hobby Abrams X in by build I plan to have a Manned turret by modifying the Abrams X turret not sure on the powerpack either the hybrid or turbine one of the weird things i found out was the Rye fields upper hull fits the Amusing hobby’s lower hull like a glove so Gino whats your insight on the powerpack ?
the hybrid diesel or or turbine?
The time frame is a factor- a 2040-ish goal is some level of hybrid, but there are a large number of challenges for a tank vs. smaller wheeled vehicle. I expect it will still have a large engine, even if it has some batteries for short, quiet operations.
Looks like an armored rear-view camera, but the experts will certainly know better’n me.
Maybe conduit entry point for the bustle mounted ECM, which doesn’t seem to be mounted on this particular vehicle ?
I don’t think so because any gear piled in the bustle rack would block it’s view.
Yep, apparently it’s a patch panel for anything requiring power.
Hello All, just got the RFM kit in the mail. Can anyone explain please what else should I not install (besides the obvious 2 containers) if I’m building the version without the Trophy system? The instructions have nothing on this. Thank you.
Thanks! It would have been nice to include some clearer steps in the manual ![]()
The instructions are pretty bad in this kit. For the configuration I suggested I am pretty sure you can use the full length side skirts and not the folded one.
Yes, having that last skirt folded back like that is purely a crew option. It’s usually done to prevent mud buildup in/around the sprocket.
Thank you both!
