I have started another conversion I have wanted to do for a while. I am backdating the AFV Club M35A1(Nancy Guntruck) truck to an M34 2 1/2 ton truck. The M34 was the original truck in the M44 series of trucks which were designed and built after WWII to replace the CCKW series of trucks. The M34 had a lower bed without a spacer between the frame and bed. It also had six single, larger tires. They are the same size as an M54, 11x20. To make all this work, the bed sides had cut-outs to accommodate the larger wheels and lower bed.
To build it, I started with the AFV Club M35A1 and cut the spacer off the frame for the bed. I also added about 1/8 inch to the frame behind the fuel tank so the bed is centered on the rear wheels. I also added resin copies of the AFV Club M54A2 front brake drums.
The bed is from the old Revell M34 kit. It is actually a pretty nice kit, very usable, but needs some TLC to make it better. I sanded down all the knock-out pin marks that were all over the exterior, added a third leg and a couple angled supports on each seat, and filled all the mounting holes. I also swapped out the undersized tailgate with one from the M35 kit. I had to narrow it about 2mm to fit between the bed sides. I also added the rear lights from the M35A1 to the underside rear of the bed and used the M35A1 mud guards on it as well.
I filled in and adjusted the M35A1 exhaust as well. The muffler had a large void on the top, which may be visible from some angles. I filled it with square-stock styrene and filler putty. I also cut down the height of the rear just below the horizontal by about 4mm to account for the lower bed. Lastly, I added a flat mount for it as well.
The rest of it is straight from the M35A1 kit. I did fill in the air cleaner hole on the right side panel and the hole where the exhaust comes through the right fender.
As mentioned above, the wheels/tires are the larger 11x20 as seen on M54s. I will be using the Def Model M54 Sagged Front Wheel set.
They look pretty good just placed where they go.
I am at a stopping point here. I am waiting on the Tamiya U.S. 2 1/2ton 6x6 Cargo Truck Accessory Parts Set so I can add the correct gun ring to it. The M34 still used the WWII CCKW style gun ring.
So more to come after I receive the gun ring.
