Omar. Very nice work. Did you have trouble gluing the tracks?
Hi All, thanks by the comments.
I put the steel clips to join the extrens because I did not like the system that the model has.
When laying wires to tension the tracks, I needed to be sure that it would not be drawn when stretched.
This was the solution I found to make the tracks fall as close to the real thing as possible.
Omar
Hi friends, finally I ended with this model, I put it in its base, I took pictures of differents angles. I hope you like them. Thanks by share your points of view. Regards, Omar
Came great Omar
Looks amazing!
Great finish on this Omar.
Man, that looks Good!
Thanks boys by the comments.
Regards, Omar
This is great work!
Thanks, José
Awesome!!
Much thanks, Ken
