Made in Ukraine
Forgot to take a photo of the front…
:raising_hand_man:
Peter, very nice build. The finish looks very shiny? Is that on purpose?
Some great builds so far all. This is my entry. It also forms part of a long running project I have just started which is separately posted in the aircraft section. Hopefully this it is ok to double post @phil2015?
I’ve been building armour exclusively to date, so chose an aircraft with rigging for my first aircraft build. Should be interesting!!!
Will be building an example flown by my grandfather in 1944. Similar scheme to the box art. Will just have to adjust the serial numbers. Also adding some aftermarket to the cockpit.
Should be fine as the other post is a personal build thread and not a campaign
Yep, it’s fine. You can’t use the same model for two campaigns, so you’ll have to pick the campaign you are entering, but it’s fine to crosspost pictures.
It’s probably the flashbulb, but indeed I added a matt finish and a little dirt just before the last picture…
Thanks @phil2015 working the weekend so will start this build Monday.
Got a good start on this. Interesting approach with the instructions threading the rigging through drilled holes. May make is potentially easier if I can avoid it becoming hopelessly tangled before I get to that stage.
Wow, those instruments look great! :+1:
Another day, and another new project starts. This time it’s an ICM 1/48 MiG-3, the first combat aircraft of the MiG dynasty, and my entry for this campaign. I’m adding some Kits World 3-D decal seat harness belts and a Cutting Edge IP to this project, and will be making it in the markings of one of the top Soviet aces, Aleksandr Pokryskhin. Flying first the MiG-3 then later the P-39 Airacobra, he amassed more kills than any western Allied ace.
last night at IPMS, I started construction and built up the gem of the engine that this kit has
I still have a few more projects to wrap up before I go full bore into this one, but I’m really liking it so far.
Will it be as dirty as in the picture? :love_you_gesture:
Oh no, not this build. My aircraft are usually not so dirty… usually… :wink:
I cracked open the box of a Miniart Austin armoured car yesterday and did make a start, without thinking of this campaign. I didn’t get far yet. Can I still participate?
If you did not get far Erwin, then if you posted a pic of the box contents it would not really reveal you started.
@phil2015 Phil … Mr Campaign Leader, Sir. I think honesty deserves a reward and my vote is ‘Yes’.
Something like this?
I’m for yes :+1:
Looks unstarted, smells unstarted, it must be unstarted… :stuck_out_tongue_winking_eye:
And what does the boss ( @phil2015 ) say???
You are In Like Flint!
Thanks :slight_smile: Now I can go loose :smiley:
