Any experts? Im trying it , just got my water slide decal paper !
Two different types of paper, one for Inkjet & one for Lasers.
Not compatible, or at least Iāve never dared to put inkjet paper through my laser printer, & ink doesnāt stick well to laser paper.
Iāve used clear (IJ + L) and solid white (L) papers.
The clear paper is thinner & much easier to lay down on the model, the (solid white) was thicker & harder to lay down.
Note, both types are noticeably thicker than commercial or kit decals, which are usually screen printed in solid colours.
Printing IJ & L, went fine, within the printer capabilities. With IJ you must clear coat, & with L, I would recommend clear coating, especially if using colour.
Note, if printing colour decals you should use a white base, otherwise you will loose the colour density. This is especially seen with yellow & pale colours.
Either spray the decal position on the model white, or use white base, or the underlying camo demarcation will be seen.
I have also used IJ paper, sprayed RAF interior colour, then base camo & clear coated, then sliced in strips to replicate cockpit framing, as the thickness is to advantage.
The finished decal will need carefully cutting out as it is on a solid sheet.
Remember, the one colour not possible with printing is white*, so white letters/numbers is difficult without lateral thinking.
White noās on black, (or black on white), for simple number plates is easy, but eg., but āprintingā transparent letters on white decal paper, and then trying to match the background colour to match eg, your Olive Drab back ground isnāt easy.
Or paint the background colour on the model, eg, bumper code green(?) then Print black bumper codes on transparent paper.
āOld Schoolā method for lettering would be to PAINT the desired letter/no colour ON the model, white, yellow or blue, then use appropriate LETRASET lettering as āmasksā, apply but donāt burnish down, and spray the vehicle colour, OD, etc, and carefully lift the Letraset with tape, but it is a very long time since Iāve seen scale useable sizes on sale anywhere.
*Alps printers, now rare and eye wateringly expensive can, but they use a solid ribbon, typewriter style, & use the whole ribbon for a single page, even is only a single white dot is used.
*HP printers (maybe other brands) now offer white ink laser cartridges, but I have no knowledge of their effectiveness or use.
Quite true. A lot of the home made decals on this site look like placards, with a very distinct edge. There is a solution though.
Leave enough space between images so that you can have a nice clear border around each decal. Cut the decal out, and sand the edges of the decal down at about a twenty degree angle. Itās time consuming, but worth the effort. Even some kit decals need this treatment.
Black outline, underlying white rectangle. Virtually no edges visible.
For when youāre doing a one off build:
Doing this has always scared me and intrigued me at the same time. Just not enough need for me to do it. So after an online search, I found a spot that does custom: https://www.hobbyistdecals.com
I also just ordered from these guys:https://modeltruckers.com
Oh, Itās A lot of āHit and Missā
Iād like to add that itās not nearly as technically difficult as it might seem. With home printer technology as it is now thereās no particular reason to hope for decal companies to make that special one-off insignia you need. Iāve been disappointed in the past with the lack of attention companies pay to the sizing on uniform patches and the lack of variety in including lesser-known units.
I donāt believe in accounting for the scale effect in painting. With decals, however, you may have to substantially adjust the color scale from the ātrueā color as it appears on the screen. For example, when printing subdued U.S. Army patches the ātrueā olive green and black combination that looks good on a computer screen will lack definition, especially at 1:35 scale. It will look like a big blob in a patch shape. I have to make the green portion much lighter on the screen to get any sort of contrast on the patch. Unless you are printing white - for obvious reasons - I recommend printing your decals on standard printer paper first to get a feel for how the colors work and what adjustments you may need to make. Thatās much cheaper than doing test runs on decal sheets
Since youāre printing your own, print a ton of them! Be prepared to have many of them āfailā - that is split or crumple - especially if youāre printing in 1:35 scale.
Ranger tabs and scrolls on the patrol caps and the shoulders were homemade.
I dig where youāre coming from. But with your unit patches, do you then apply them to something before gluing to the figure, to give them a bit of thickness? I find that not doing so makes them look like, well - decals.
No, frankly Iām not a fan of that, at least at 1:35. At that scale I feel that anything thicker than a decal looks cartoonish and sculpting a patch at 1:35 will inevitably be way off scale. I know that @ReconTL6 has molded his 9th ID patches for many years. He has a certain aesthetic and Iām sure heād agree with you. But I also find that anything with a more complex shape than a circle or a square would be maddeningly tough to sculpt at that size - say an SF patch with the AIRBORNE tab or a 101st Airborne patch. If you arenāt sculpting a patch, then Iām not sure what other material you could apply a patch to that will lay down properly on a sleeve or a chest, especially if the figureās clothing is portrayed with multiple folds.
At 1:16 scale, I would sculpt a patch and I have done so before laying the decal down. I just donāt have any photos of that handy. But itās still a lot of work to get that sculpted piece to not look cartoonishly thick.
