First I am sure some will not like this forum location but figured since it was AFV postman thread that folks asked for a review this seemed to be the best spot for them to see it.
I bought model G233 from Amazon as I was looking for a bigger needle for primer painting. It comes with a 0.2, 0.3 and 0.5 needle and tips. It also has a quick release connection parts.
The model is very similar to the Iwata HP-CH gun I already have. This Iwata has a top cup but also a MAC system. My Master did not but I have seen other Master models that have this feature. I am not refined enough to appreciate this feature.
There is a difference to the feel of the brushes when using. Iwata seems tighter and Master has a looser feel. Could be use and cleaning with Iwata. Not that one way is better, it’s just different. They both spray well for me. The bigger difference I noticed was inside the cup. Iwata doesn’t give you the extra space that Master gives with a much larger well area. While this didn’t seem like much, it was an extra area I had to pay attention when cleaning as paint was collected in there.
Iwata
Master
While I had issues with my Iwata with 0.3 needle and stynylrez primer in the past and I fully admit it was probably user error. Using the .5 needle, I poured the primer from the bottle and sprayed with no issues from the primer.
The Master airbrush did what I wanted and will be my goto primer gun. I do still plan to use the Iwata for my day to day (ha, I don’t spray that much). For about $40 I cannot complain about the Master
Airbrush.
Hope this help anyone on the fence one way or the other about the gun.
*I did add the quick disconnect to my existing hose and Iwata moisture trap because the disconnect has a shutoff value and it’s easy enough to spin off the gun myself to change out. Instead of upgrading the other guns to a disconnect.
