Looks good so far but I totally get about what you say with regards to the wheels… That would kill it for me… I get fed up with 3 parts for a track link…
I’ve got this one but was unaware it took 7 parts for one wheel. I already have a downer on wheels and this will tip me over the edge!! But I will be watching this to see how it goes.
I see said the blind man lol. Thanks for the info my friend. Smart move by the manufacturers as it makes a perfect sense and not waist $$ by repeating what has already been made.
They don’t compare to the Meng one BUT the LIC Version of the Academy kit is decent and can be a fun build. You can use this kit to build an early (no loader’s hatch) or later Merkava IV. The hull shape is nice, the suspension decent, detail is good and there is antislip molded where it should be. The tracks have sinkmarks and are a bit on the thin side, so aftermarket tracks would be a huge improvement. Legend used to produce a single piece bustle rack but the ball and chain is a huge PITA to do. Academy provides PE parts for that but provides the balls in two halves that you need to remove from the trees. If one is looking for a cheap MkIV and especially wants to do the first barch of vehicles the Academy kit is ok.
EDIT: Meng also does an early IV kit, kit no TS-049, haad forgotten aboout it.
Thanks, for the time I 'am impressed from the kit, it takes his time to assemble but until know everything fits ferry well. But still it’s a lot of filigree parts.
my merkava IV built out of box
the most difficult part was the assembly of the tracks I had to make myself an assembly jig to make my work easier
I used the paint ak real color sinai gray 1990
