An interesting note I saw was the article was dated 2020, so it was part of the fighting from 2014 Crimea and Donbas fighting and not as much about today’s fighting (that I kinda assumed at first) other then those vehicles are probably in use.
Come on Trumpeter you got all the parts to print a new BRDM version.
Thanks, not versed in Twitter searching. Google typically gets me a blown top -2, which isn’t the same. I know the generic name but I wonder if there is more specific number/name. One site suggested the 2U was more of export model which would make sense and not seeing many.
A question on these cans. I am building a T-80U and at first I thought Trumpeter failed to provide the cover for the can. But my research shows this is open (see small opening on top left of the can). I don’t get it. Why would this not have a cover to protect from the elements? The original small DSHK can was closed here.
BRDM-2U command, usually found in Russian maneuver battalion and regimental headquarters and artillery units. Special communications equipment, two radio antennas on each side of the hull
-BRDM-2UM is later version with improved communications equipment
-BRDM-2U2 features a sword-like antenna on the rear deck
-BRDM-2U1 is noticeable by the large box-like structure on the vehicle’s roof
Trumpy will jump on it dont worry, Bohdana, Ceasar, Neptune…i think they are already collecting info on it. Edit: if they dont, then UKR companies will for sure. 1/35 Neptune launcher from Miniart please…
