The Trumpeter Kazakhstan version is 99% the same as the current Russian version :wink:
The Kazakhstan version is totally wrong, the closest is Obj 199 from trumpeter or the Terminator 2 from Zvezda even then you will have to change the side armour and main panoramic sight.
Well I’m working on an LTAS cab as we speak so maybe soon we’ll see an actual kit with one!
He seems to be a movie buff.
Apart from missile covers and the gun covers they are identical missile covers and gun cover are available from one of the aftermarket manufacturers as etched parts trumpeter Also has some of these parts as Options in the kits I did say 99%
The goal with the ā€œSpecial Military Operationā€ keeps getting adjusted to try and match the achievements on the ground.
The Ukrainan military forces were ā€œmarketedā€ to the Russian publich as incompetent and ineffective and the SMO was marketed as more or less a walk in the park.
Ukraine resisted a LOT more than anticipated. The goals were not being achieved so the goals got readjusted.
The problems experienced by the Russian army still needed an explanation → It must be NATO troops in disguise.
Russia says that Ukraine has lost upwards of 160 000 troops, the Russian losses are given as 6000 (six thousand). To make up for the Russian losses Russia needs to mobilise 300 000 ā€œsoldiersā€.
I never managed to understand Russian mathematics …
Which is the most current version ? the one with or without the missile covers ? or are they both fairly current but just different versions for home or export use ?
As opposed to sheer incompetence:
M
Scchhhhh … The Glorius Red Army can never be incompetent …
If only I were that simple! Admittedly the Kazakhstan version will give you the side armour (although you would have to shave all the detail off) and the stowage boxes the turret is still wrong it’s not just a simple case of the gun and missile covers there are a lot of other details especially in front of the commander and gunner, ask me how I know, currently going through a conversion, worst still small scale, no aftermarket and only one kit to start from.
L119 in action (with mismatched tires…)
Sounds good Mike. Lets see how much I need… ā€œstarts countingā€. :grin:
German Continental GelƤndeprofil Reifen. Maybe from an Unimog truck…
And you will never understand Russians.
There were pictures of Biden and Ursula in decent shape, but the administrator deleted them. At the same time, an indecent picture with Putin continues to hang above.
But it’s easy for me to understand you: you yourself came up with the rules that you shouldn’t write about politics in the topic about modeling, and then you yourself violate this rule.
And so always and in everything.
rge Russian invasion of Afghanistan was also sold as a walk in the park to the troops. i read that they would be ā€œbuilding schools and planting trees for the benefit of the local populationā€.
similar nonsense was spouted by john reid to British troops during ISAF’s deployment in Afghanistan as part of the war on terror.
Yes please
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/309366011_437394411824223_3636142600720658142_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=730e14&_nc_ohc=aZcfVhGMit8AX-9eDwK&_nc_ht=scontent-mrs2-1.xx&oh=00_AT8TgD9LLmmbUqMdEOPEhzmKgrJ1RhbVLfLrzkZeu-GL4A&oe=633A2F86
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/310223396_437394501824214_6872587343360911353_n.jpg?_nc_cat=109&ccb=1-7&_nc_sid=730e14&_nc_ohc=j1dTMLL6oUwAX-v1l3R&_nc_ht=scontent-mrs2-1.xx&oh=00_AT-9zCj_X-T88eWIKitlVWlwTM6ApIBiYWRWDzBBdfQK2Q&oe=633B1681
https://scontent-mrs2-2.xx.fbcdn.net/v/t39.30808-6/308959636_436050095291988_574591316715524364_n.jpg?_nc_cat=107&ccb=1-7&_nc_sid=8bfeb9&_nc_ohc=kJXE2fQiWlYAX8ykjNN&_nc_ht=scontent-mrs2-2.xx&oh=00_AT8CHZKexqA000hUYnHzV0vrW3nwZTez4cwnNn_rHTHh5A&oe=633A3A54
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/308922782_436050041958660_3918999266071517276_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=8bfeb9&_nc_ohc=dxY3F4wehNkAX-XZtTG&_nc_ht=scontent-mrs2-1.xx&oh=00_AT8P_VedEKwYYou3aeTIrJauFJ78kwvsXBXEJX3t8dRrZA&oe=633B0F85
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/309066395_435122068718124_2677076800634687699_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=730e14&_nc_ohc=9kXTQX1AUPgAX_DswOc&tn=x1UztIxmt_lEuAoc&_nc_ht=scontent-mrs2-1.xx&oh=00_AT_YKTLawMFgW4gPrUr1zH5lmM3iPxMvP0vpW6zUb7dCNQ&oe=633B6FCD
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/290450466_435358982027766_8392936764171769663_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=8bfeb9&_nc_ohc=bMg5zuEoCxoAX8imyQ1&tn=x1UztIxmt_lEuAoc&_nc_ht=scontent-mrs2-1.xx&oh=00_AT9z6Kn4q98Js_BbzrX1Uhd_PORP-aKoxISiFxACKyGM6g&oe=633B94E8
https://scontent-mrs2-1.xx.fbcdn.net/v/t39.30808-6/307422266_427609309469400_12524595773752508_n.jpg?_nc_cat=105&ccb=1-7&_nc_sid=730e14&_nc_ohc=c_pBdgXk7XcAX9wJCJW&_nc_ht=scontent-mrs2-1.xx&oh=00_AT9_uwAREaFIIapxmmt_ipXny4U48jC-Rg0I9n73LOwdbg&oe=633B467C
Guys, serious on toppic question. Whats with the supposedly superiour new stuff ? Where is it ? Wheres the Armata ?
