Let me guess: If you turned the camera around, there’d be a similar-sized pile of empty beer cans?
If you tilt the camera… Juuuuuussssssttt riiiiighhhtt!
i think most of us use twigs and sticks found in our garden or local park.
This! A+++
Otherwise, small wood dowels or plastic rod cut to size. Texture added with putty to make irregular etc. However, that’s a lot of needless work vs picking up small twigs and sticks as Klaus suggests.
I didn’t thought it’d be that easy
Sometimes styrene produces better scale results. While this is flat…
You can use the same technique to make “logs.”
Not yet,
not next month
but
who knows when?
Wasn’t there some rumours about a model of this monstrosity?
There was a resin and pe model made not sure if it’s still available Lebedenko tsar-tank, Kora Models A7226
I found it.
I was thinking about this:
I do hope it turns up for real and not just CAD-renderings
I think these are the factory built cages- seen on T-72B3, T-90M and T-80BVM.
