Any tips on thinning mr color? I use MLT and I still have this issue when thinning:
it’s too thick, still too thick, still too thick, waaaaaay too thin.
I don’t use it that much, but there are a handful of colors they have that seem fairly indispensable.
Almost always 50:50. Pressure at 12-15 psi and build up colour with multiple passes. Usually use Iwata revolution with 0.5mm needle/nozzle.
Sometimes add Satin or Matt varnish to gloss finish mr Color paints. Never quite worked out the reasoning for the variation in finishes they do.
Thanks much. This is very appropriate as I use the same airbrush setup as you for most of my work!
What Jim said. 100% success rate.
