How 'bout a nice Brick Red? ~ the Wheeler Pharmacy:
This is a custom structure in O Scale, built out of assorted wall panels from “Design Preservation Models”, plus various other details salvaged from the local hobbyshop’s “junk bin”.
(Chimney, Skylight and both rear Roof Awnings are all “found parts”.)
Here painted with the Red Oxide and a Matte Hunter Green and then weathered:
And shown below; a rear view before final weathering:
(I show this photo so you can assess JUST the red brick color for yourself WITHOUT the addition of all that weathering.)
_____________________
p.s. ~ I am posting my revised artwork for the big Coke sign (at full resolution.)
Should anyone else wish to download this artwork to print out at home for use on one of your own brick structures, you have my blessings.
I simply printed it on the cheapest and thinnest typing paper I could find. Then cut it out and applied it to the brick surface using generous amounts of Future Floor Wax both on the brick surface and on the paper sign itself. (I soaked it!) Then I used both a medium large brush and my fingers to push the sign paper into the pattern of the brick.
Finial finish was to spray the entire building with Matte Clear (Tamiya TS-80 rattle can) to kill the shine of the floor wax.
Use this artwork as you see fit with my blessings.j
