I am moving to Houston Texas at the end of this year from Canada. I’ll be driving down and the box I plan to pack models in will be coming with me not the movers. I am curious how you guys pack for long trips? As I finish models now I plan to just put them in a box for the move instead of on a shelf.
I was thinking of lining a cardboard box with pink foam of the type used in dioramaras and cutting it so each model has a slot more or less the exact size of the model.
I’m not sure why anyone would do that.
As for your question, your plan sounds good. I like the boxes that printer paper comes in as the lid comes off easily. I actually took three armor models all the way to Japan, and took two back, in those boxes. But instead of foam I just poked holes in the bottom of the box and used twist ties to secure the models to the box.
Way back in the day I’d also glue foam to the upright portions of the box so I could rest a second tier of cardboard on it.
Thanks for the help!
Haha. No choice! Work here has dried up and Texas is booming
I moved from Southern California to the Phoenix AZ area last year. I used those big flat Tupperware type bins to move my builds. For my armor kits I lined the bottom with a layer of thin foam, then had more foam strips surrounding each build. Enough to immobilize them from sliding around. For my aircraft builds I used a combination of foam to support the airframe, and poly fill fiber to surround and isolate each build. Out of my 300 or so builds transported, I only had a handful of small pieces get damaged in transit. This is them upon arrival before unpacking.
I would add putting each model in a zip lock bag, so if things break they are contained within the bag and not just the box.
That’s a good idea! Could defintley see small parts breaking loose never to be found again
The stars at night are big and bright.
I’m no bloody help at all, so I’ll just wish you good luck!
Thankfully I just got back into this hobby and will only have about 5 completed models to move. I pity those that have to move 200 compared masterpieces
What sort of models?
No idea on safe transport for long drives with assembled model aircraft. I just toss those in the trash bin
Assembled model tanks & AFV’s are pretty easy to move ~1,500+ miles without damage. @18bravo & @Stikpusher give excellent solutions very similar to my own experience.
Transport Box or Sterlite Plastic Tote
1.Copy paper box/printer paper box or tote.
2.Line bottom with block of foam.
Place model on foam at least 1/2 inch or 13mm from box sides.
Use toothpicks to secure model in place so it can’t move or shift to left or right.
If vertical movement is a concern as @18bravo suggested
It’s even easier if the model is secured on a base.
4 of the 5 will be tanks, one will be a spitfire model. I think lateral movement is more of a concern. Once the box is in my trunk. If I get severe vertical movement on the highway in my car I fear I’ve made a bad driving error
Could I butt in with my own problem?
I need to move five builds with me all the way from NM to NY… it would be easy if I was driving, but I will be flying over so Im really scared about how I could transport them without damage.
Anyone have any tips???
Secure them to a base of wood/plywood. Construct a wood box with the model base as the bottom. Use screws not nails to attach the base.
BTW… have you been to NY lately? Why make the trip?
I flew four models all the way to Japan once. I used copy paper boxes. They’re very sturdy, the lids come off easily, and you can glue triangles of cardboard into the corners to support a second deck if you need to. (upright triangles, like three sided pillars) I secured my models to the bottom of the box using twist ties. It worked perfectly on the way there AND back, minus one model I left at the Tamiya headquarters, but that’s another story.
I moved 1 year ago and used manly cardboard shoe boxes for the tanks & AFV that i collected over the years (i knew that i would move at some point) and for the 1/72 smaller items, 1/48 would go in lager cardboard boxes and all would placed into lager cardboard boxes cheap but i must admit i really like Stikpusher suggestion as these will nicely fit and much more sturdy than cardboard boxes (yes i had some casualty’s) oh well it happens
Whenever you receive a package containing delicate items, take note of the shipper’s packing techniques. On occasion, I’ve been known to save packing foam, corner protectors and edge protectors which come inside packaging from the best of shippers. You can even buy said protectors on Amazon or at a UPS Store. HTH.
—mike
Ooh thats a good idea. Did you check them or were they a carry on?
And if they were a carry on how did you haul them around with you?
I carried them on. I hand carried that box everywhere I went like it had nitro-glycerin in it. A pretty good trick in Japan.
