I’ve been look up videos and photographs of the Panhard EBR. Amazingly, every single Panhard EBR picture I’ve seen are display models, while videos show them in noncombat maneuvers. Where haven’t I looked?
Try looking for those in Algeria during the war there.
I think I’d like to pick up a kit to go with my Academy Legionnaire figure
Be aware that the HB kit has many flaws and inaccuracies. I mentioned them in the article about my build in my site.
The turret of the kit depicts the late model with the 90mm gun. It is not suitable for the war in Algeria period.
Olivier
Thanks for the heads up. One for my giveaway pile.
Hope the Takom AMX 75 is any good.
Didn’t hobby boss make two kits of the EBR?
I thought that they made two different versions.
You’re right they made the both versions. However they didn’t fix the issues on the latest model. I have been told that the FL10 turret (AMX 13 one) is badly depicted.
Olivier
Tom
The AMX13 /75 is a good base. Have a look at my series of builds of the various Takom AMX 13 on the site. AMX 13 challenge
Out of the box it builds into a decent early French model. The IDF version needs some extra work depending on the time frame.
Olivier
That was used in Algeria I assume?
Yes Tom. However this was the early version with the 75mm gun on the FL11 turret. HB only gives the 90mm gun with its FL11 turret.
Apart from a so-so conversion by Azimut there is no aftermarket set you could use to depict a EBR during the conflict.
I have to check if the FL10 turret was used in Algeria.
Olivier
I guess it was.
This EBR “Corse” belonged to the 3e RCA. November 11th parade in El Kouif (1959)
Another one near Arba (1957)
Source : https://www.anciens3rch-3rca.fr/historique-3-rca/alg%C3%A9rie/
The 3e Régiment de Chasseurs d’Afrique was chosen for the FL-10 turret trials.
Thanks H.P.
Olivier
Great pics there Frenchy. The lower one looks to be in a sand color.
The turret is painted exactly like the ones of the AMX13s in operation Musketeer in Suez. I guess the turret has been recovered from one of the tanks and fitted onto the EBR hull.
Olivier
Sure that makes sense, that Operation was in 1956 I think right ?
