Hi Guys, thanks for all the feedback. Are we talking about all ten wheels, or just those skinny front ones? I see DEF does sets for both. If I can get away with just the fronts I’ll be able to fix the other 2 Italeri M925 kits in the stash too.
Id really like to build one of these to Bigfoot standard like Heartless Wonder, it looks great on those big singles.
Maybe, as Gino noted, AFV will make a cab for the M800 from their M54 kit.
I would replace them all so they match. I prefer the Def Model wheels as they look to have the proper rounded profile. Make sure to get the newer, corrected version for the rear wheels though, DW35116.
The first version was molded incorrectly and they stuck out too far past the bed sides. Some of the first version boxes say “Released August 2018” on them, while others don’t, but they are DW35110.
For the canvas, you can either drybrush with a lighter green and a sandy color, or do a wash of the sandy color to weather and bring out the details. I would do both, drybrush first, then wash.
After some more research, it appears that some of the last M813s used were rebuilt w/the big single wheels/tires. It appears that these were mostly USMC vehicles that they rebuilt to save money as opposed to buying new M900 series 5 tons.
This one was even seen in use as late as the early 2000s in Afghanistan.
“A truck full of U.S. Army soldiers fords the Pech River in Pech Valley, Afghanistan, during operations on April 9, 2006. The soldiers are attached to Charlie Company, 1st Battalion, 32nd Infantry Regiment, 1st Brigade, 10th Mountain Division.”
I wonder if the truck above belongs to the U.S. Army. In the hi-res version of this picture, you can notice that the driver appears to be an Afghan soldier…
Apply more liquid cement and see if it softens them enough to pop them off. If not, cut the wheels off as close to the backside as possible and use some styrene rod to make new ends for the resin wheels to slip onto. I would also use some heavy metal wire to attach them as well for extra support.
Thanks Gino, I’ve noticed the Tamiya thin quick drying cement causes quite a reaction (separating) when added to a recently glued part. Despite its quick drying nature, could this be the right glue for the removal process?
My M813 is finished. DEF wheels, 3d hubs by Dennis and James at Shapeways. Mission Model OD Faded 1,2 and 3 for the tarp and cab roof. Tarp is newer than roof, hence color change.
