Sci-Fi and Alternative History Campaign IX
Looking Great, Mike! It will break up the camouflage colors nicely and create some contrast.
Thank’s guys!
And speaking of the “Tow Bar”…
—mike …:flying_saucer:
Wow! This thing is big! Is the tow truck 1/48?
Hi Jesper,
Every now-and-again, I need to remind myself that everything is 1/72 scale. The Haunebue IIb saucer is 14” (355.6mm) diameter. …:coffee:
Thank’s for having a sighting!
PS: I’m building these two trucks for the ‘Convoy Campaign’ as ground support vehicles for the Squadron Models (SQM0001) Haunebu II German Flying Saucer UFO
Special Armor (72001) 1/72 HANOMAG SS-100 Gigant “Schwerer Radschlepper” Heavy Tractor
Roden (ROD 738) 1/72 VOMAG 8LR LKW WWII German Heavy Truck
Holy cow that looks slick.
I reckon that engine is going to straining in the SS-100… That’s a big old chunk of metal to be pulling … It looks really big now you see it next to the truck…
Without scrolling back a million posts (slight exaggeration and being lazy :grin:) had the paint scheme been decided for the saucer yet Mike?
It helps if the saucer crew releases the hand brake! :grin:
It would help even more if the wheels were all pointing the same way… :clown_face:
Awesome!!
You have a great eye for detail.
Thank you all kind sirs!
I’ve got a scheme all worked out in my head (der Luftwaffe Squiggles). It’s extremely ambitious and I’m absolutely clueless how to pull it off. :face_with_diagonal_mouth: … This is gonna’ stall things for sure. :construction:
Hey Peter,
They do… up! :grin:
…with a little help from Bob. :hammer_and_wrench::grin:
Thank’s for having a look!
Another small update on the Haunebu IIb.
Metal Turret Cannons got some primer today.
Tamiya (87064) Fine Grey Surface Primer (rattle-can)
There is a YouTube video from Keeto Model Works showing the painting of squiggle camo (Wellenmuster/Mäandertarnung) on a Hs129 using an empty paint pen filled with the appropriate camouflage color; you may be able to adapt this technique to the night-fighter pattern from that image.
@ Sean (srmalloy). Thank you so much for sharing the video link! That’s a great technique and exactly what I was hoping for. I can hardly wait to experiment! :worm::paintbrush:
Cheers!:beer:
Well, it’s about time we got better TV reception around here! :satellite:
Aft Antenna scratch-build (L 22mm). Notched with a small triangular file and assembled with CA glue.
• K&S Brass (8160) Rod .032” (.81mm)
• K&S Brass (8159) Rod .020” (.51mm)
Hmmm… Can there even be a forward, aft, port and starboard on a round ship? :thinking:
“Who cares?! Now I can watch ‘Lucy!’” :tv: :face_with_monocle:
So that was this morning’s warmup. Now for the real fun…
As mentioned earlier-on, there was landing gear jiggery-pokery “afoot.”
What you see here are more huge chunks of styrene hacked away from the cheese wheel. After which, the gear assemblies were permanently attached with ‘Bob Smith’s Quik-Cure Epoxy.’ :stopwatch::syringe::sweat_drops:
On the flip-side… Now that the landing gear has been corrected, I closed-up the ginormous cavities left behind by the Mad Hacker. :hocho: :hammer_and_wrench:
Now with the wheel bays out of the way, the doors can be attached. A couple more personal touches and a lot of putty to follow. Please stay tuned… :tv: :satellite:
—mike …:flying_saucer:r
Nice work Mike, some serious surgery undertaken there!
Cheers, D
Good effort all round Mike… It’s taking a lot of work, but your thinking outside the box is going to turn this into such a great unique build… :+1:
Damian and John. Thank’s guys!
Now that major surgery (on the cheese wheel, tortilla, frisbee, hub cap…) is done, hopefully it’s time to move on to a little more detail painting. … Whew! That was one lengthy procedure! :adhesive_bandage::sweat_smile:
You know that VHF is 30 - 300 MHz so that antenna array is good for FM broadcast receive as well :radio:
Nobody will ever see them…
Hello all,
My original plan was to add lightening holes to the very plain landing gear doors. However, I lack the proper tool to create them so I had to scrap that idea. Instead, I stuck-on strips of Tamiya Masking tape (2mm) in hopes of creating a little micro-relief under the paint. :hammer_and_wrench:
[EDIT]
I also did some add-on to the Tow Bar. :hammer_and_wrench:
Outrigger T-handles (imaginary axle-locking mechanism). Once again, Vallejo Deep Yellow (70.915) came out to play. :yellow_circle:
Interesting technique. Can’t wait to see the result under paint :bulb:
