Still wait’n for those “chains that bind”. Coming from China! I just hope they send it via air as a small envelope.
Chains Arrived from China:*
Unfortunately while very nice, they turned out to be much too small for the heavy duty job here at hand.
Gas can included for size comparison.
So ~ still on the hunt for the proper sized, rather massive anchor chains needed for the 115 and 116 tie downs.
Shame chains are not suited for this one.
I hope it doesn’t delay it to much build wise.
On to a basic interest question for me. Trailers. Now I know from your previous posts etc, and seeing others do them, you enjoy building them. Do you just have a thing for trailers as a trailer and model them, or do they get done as a big picture you see with a load or being pulled ?
I appreciate the amount of effort and research and the scratch building that it all involves, but I wouldn’t ever build one, which is why I enjoy watching them being constructed here.
John ~ All I can say in answer to you question/statement is that the trailers are an often overlooked aspect of the whole “softskins” segment of the hobby and I enjoy the additional interest they add to a model.
Also clearly trailers are a modeling aspect that appears to be “taking off” as to the model manufactures offering more and more of them. - So perhaps “never say never!”
Since there is no air compressor on the trailer would not there be an air line from the towing vehicle to supply the trailer air tank?
Absolutely!
I have yet to model the parking brake lever cable or the air and signal lines.
(Being distracted by a big 8x8 MAZ Russian truck right now!)
Time here for a bump up!
Some small progress on my new Lanz Tractor:
The chassis, engine and radiator housings.
As to the question of how the winch on the 115 was powered: - it was a hand crank worm and gear arrangement. However just as with the rear axle body jacks there was a two speed gear choice.
In the case of the rear body jacks, one speed gear for quickly lowering the body and a power gear with more mechanical advantage for raising a loaded trailer bed.
As to the winch; again there was a speed gear to be used when quickly walking out the tow cable and a power gear to use when drawing in the winch cable under load.
Apologies for flying off-topic with the post of the MiniArt Tractor.
Probably a, Bruckenleger auf PzKpfw II Ausf D
https://www.materielsterrestres39-45.fr/fr/images/charsspeciaux/allemagne/genie/bruckenlegerpanzer2/t_brucke_ii_ausf_d_134.jpg
Post deleted by author
Thanks for the useful tipps
