Stalingrad factory diorama 1:35
Use both in different areas of the dio.
As Gino says. Use both
I concur. They both look very good.
—mike
Both indeed, just be aware where to use them, one is like only plaster gone, the other is almost explosion/shell damage…
I feel like if two of these ‘big holes’ should be on the concrete slab on top of the walls the damage to this slab will not corespond with the damage done to the brick walls. :man_shrugging:
I made the bricks on the inside where they will be visible:
Today I ordered the plastic profiles. I have not made much progress for a new update post. I just wanted to post this so you know that I had not give up on this. I have a big exit exam in my school next month so I will not be able to dedicate as much time to this project. Cheers! :smile:
School is more important!
You don’t always have to choose. College (St. Lawrence Univ) required a January project. I did independent study. I painted 12 Historex Napoleonic figures (yeah I’m old but at least they weren’t Staddens) and wrote a bit about each one on an index card in French and in English. They went on display in a glass booth in the administration building.
Small update:
I worked a bit on the corner wall. I also made telegraph insulators with a stand.
I tried to hide with this horizontal U beam the ugly connection between the two sheets of foam. It does not serve any purpose but I think that it could be there.
I will see how will this part look because the corner is made 2 sheets and there are small gaps in the bricks where there should not be any.
What do you think about the size of the insulators? I was worried it will be too big but on the picture it seems fine.
I made new construction for the indoor pipes:
I started working on the pipes:
Small update:
Aloha Gloch,
The interior pipe supports are a great improvement and believable for the task. The pipes are also looking great. What is the product for the fittings and flanges?
Happy Modeling,
Zon
Hi!
The nuts and bolts are from Plus Model
I bought the flages here:
Oh man, it’s looking great! Nice to see some serious foam work! Keep up the good work. /Erik
Thank you Gloch! Happy Modeling!
Great lookin’ work goin’ on in here.
J
Sweet, the fittings are crazy. That is some fine detail work, if I do say do myself,…and I do!
Thanks everyone for the support! The exams went really well, now I have 3 months long break from school and then I am starting at an university :smile:
I made new roof trusses. I think that the roof construction is done:
The overall geometry of the roof construction is a little bit off. But one could say it is due the bombarding.
I added some tactical damage to mask the imperfections :sweat_smile:
Wow, great work all around!
