Takom Sdkfz 250/1 build
Step 1 done. Good fit so far.
Step 2 almost done.
Roadwheel arms have a bit of play and I’ll have to figure out what the neutral position is.
Looks good so far. :+1:
Thanks, figuring out the ride hight will be interesting.
Except for a possible track length issue a terrain can fix any issue with the height.
I guess in time I’ll figure it out.
You know it should be below the idler and sprocket center line. Add a wheel or two on the outside edges and add Legos or some other material to raise the hull to give you a nice track sag line to your eyes.
I have this kit, so looking forward to see howvthis turns out. Can hardly wait for the Das Werk 1/16 scale. Oh, down my beating heart.
I’ve been using Panzer Tracts 15-1 to help out.
Some puttying is needed.
Front suspension is getting on the lower hull.
All the front suspension parts are on.
Added the small rings at the end of the front tow hooks.
Wheels!
Salami sliced works well, but part B10 is actually B11.
I’ll be keeping an eye on this build, since I have two of these in the stash, plus the “Grief” on order from my LHS.
Some of the transmission assembled.
Bought it and its on the way…not too sure if I’ll build this as a pre-lim for the 1/16 scale from Das Werks…
I hope this helps out on your build. :slight_smile:
Sd.Kfz. 250 Sonderkraftfahrzeug 250 German Halftrack - AFV Walkarounds - Britmodeller.com
Thanks, I noticed that it has hand grenade holders on the storage box, which I’ve not seen before. I’m now looking for engine compartment photos.
I think the transmission is done. I added the tread plate from Archer.
