Nope, I think you’re right mate…they are the tank sheets ![]()
I need to get busy…
I’ve never noticed that before until I magnified a pic to see if there was a texture to the sheets. I’d be interested in seeing one of those sheets unrolled to see what it looks like.
Yeah, it looks like a definite printed cam pattern
I guess I’m lucky, the tank I think I’m doing has the whole thing wrapped and stowed on the nose armor (see the first pic I posted), should be a little easier to do, unless I want to punish myself.
I went ahead and hung some barrels on the rear, using a couple from Diopark, the Eduard straps and the ratchets from the Tamiya kit barrels. After adding them I realized I probably should have left them off and done the straps but I kind of like the look of the thing with the big drums there. I plan on looking for pics of different colored barrels in use too, but for now they’re painted green as a primer and undercoat.
IMG_4338 by Russel Baer, on Flickr
I also mounted the nose armor and did the headlight wiring, painting under it as well.
IMG_4339 by Russel Baer, on Flickr
I really hate painting, partly because as soon as I get color on I remember something I forgot to add, fix or change.
Yep, me too.
Yes without fenders it’s very cool!
I have not stalled on this, just working very slowly…
Yeah, right. But I did get the painting of the tracks started.
IMG_4415 by Russel Baer, on Flickr
Nice to see you here Russ. What colour did you go for with the faded track pads ? a dark grey ?
Exactly. Vallejo light rubber maybe?
Cheers mate ![]()
I haven’t quit on this, just got a little sidetracked. I had it in a light coat of Tamiya sand and didn’t really think the color was warm enough, so I put it all aside and percolated on it for a while. Then when I was painting the Tiran (for the IDF campaign) I really liked the Vallejo desert tan I used an an undercoat on it, so I did a quick spray on this too. I think the color is maybe too “orange-ish” now but I can easily lighten it a bit with weathering.
IMG_4510 by Russel Baer, on Flickr
Compared with the image below, for illustrative purposes only, from “Images of War”, Challenger 2, pg. 61
IMG_4277 by Russel Baer, on Flickr
British sand yellow is very yellow/orange when compared to something like US desert colours. The closest I have come to matching it is Mission Models MMP-039 British Sand Yellow Modern. Having served on vehicles painted that colour it’s very close to my eye. This is my Husky TSV painted in it.
I use ak real color rc 093 british sand yellow paint however I haven’t seen it in their new range the old range in the glass jars is discontinued
Looking good. I used a mix of Tamiya dark yellow, dessert yellow and white with a few drops of yellow green added. 1ml dark yellow, 1ml dessert yellow, 3.5ml white and six or seven drops of yellow green. A convoluted way of going about it but I was pleased with the result. Build is on here.
That sand yellow is a nice match … And that mix you did Jim @iwatajim turned out great as well…
Good info all. Keep in mind I’m using rattle cans though, have to spray outdoors.
Modeling mayhem has struck. I was moving along nicely, scrubbing the tan off to show the green underneath, being very careful to do it in high-traffic areas only, got where I wanted and then shot satin clear before adding decals. I have the Star sheet for CR 2 in Iraq, and doing a fair amount of deductive reasoning, settled on markings. I was careful to trim as much clear film as possible, used Micro Set and -Sol, and not only couldn’t get the decals to properly lay down, they silvered something horrible, or the film wasn’t clear. I was very vexed. I tried Walther’s setting solution and that got them to settle down, but I could still see off-white film, and no amount of re-application of the Walther’s helped. So I put all the pieces, turret and hull in warm water and let them soak for a good 24 hours, and was able to remove the majority of the Star decals using a paint brush handle with the end cut flat, think a semi-hard chisel, without wrecking the paint underneath… too badly.
I’ve used Star decals before and always had an issue getting them to settle, but never have I seen the film stay semi-opaque. Rats. So, digging through what i had on hand, I just took the easy way out and used the kit decals. The problem there is they’re for an entirely different unit and I have no pics of any of their tanks with the rubber skirts off, so my “very close to the pic” build is all of a sudden theoretical. Anyway, here it is as it sits now, Tamiya decals on and matt clear on.
IMG_4526 by Russel Baer, on Flickr
I also realize the Union Jack probably is inappropriate, but since I’m so far away from my original goal, what the heck, it adds some good color.
Looking nice Russ, heres another of 11B.
Images from online and for discussion only.
Also, although its another Sqn, the lower skirts were not always fitted.
Thanks!
