Tamiya Cromwell WIP
I have recently been reading up on XXX corps and the Market Garden operation in general. This inspired me to build up a Cromwell (I love British armor) from the Second Welsh Guards. My idea is to depict one somewhere near the Belgian-Dutch border before the push into Eindhoven. With this in mind I wanted to depict it as more of a staging area type scene with more relaxed troops, a calm before the storm type of settting.
I have so far gathered the following materials, the Tamiya Cromwell with Eduard PE set, and an Aber barrel, along with Hobby Boss Indy tracks, and the Gecko MG team marching.
I also plan to add these three figures from Ultra cast and Trex
All inspired from a combination of these two photos
Step 1 in somewhat of a departure had you start in the backplate. Not much of interest here. There were a couple punch marks to fill on parts C22 and C23, but other than that the parts all fit splendidly. I am also going to replace the kit smoke dischargers with the PE
The brass is just dry for together while I wait for liquid flux to arrive and then I can solder together
I should also make the point this will be a slow build as life will be in the way but I plan to keep this fairly updated unlike some of my other logs the stalled out :frowning:
I think T Rex makes a few 3D items for the kit?
That they do.
Very interested in the build as I picked this kit up in our club gift exchange last night.
Excellent! Good start and I like the concept you’re aiming for.
Very nice project you have going there. I have the Tamiya kit and will get to it one of these days. Great addition of the figures as well.
Is it me, or does this figure resemble John Clease?? Lol
That they do, I don’t think I’ll get any of them as the Tamiya parts are quite nice.
@Tank_1812 it is a very nice kit. I was quite surprised, for a 1997 kit it has really nice subtle surface detail like welds in the road wheels and rolled armor texture
@metalhead85 yes! I thought the exact same thing!
It does look like John Cleese! Cue the Ministry Of Silly Walks!
A great build started Mead, I’ll be watching. I have this in the stash too.
Maybe I will have to hide a sign somewhere in the diorama with “Don’t mention the war” as a nod to Fawlty towers
It saddens me that given the proclivities of our Civil Servants at the moment, this clip almost isn’t funny any more(!)
If it matters to you, the kit has a type C hull as made by English Electric, and there were not many made and used in NWE. The kit decals for 5 RTR are correct for the kit, and the Welsh Guards decals are presumed to fit the real vehicle of this type. The other 3 markings are known to belong on different hull types.
Good info indeed, I knew it wasn’t an F hull (sadly as they seem to be most abundant), do you know if a breakdown of numbers exists between the various types? It looks like the main difference in C and D was the drivers hatch style and F changed to a side opening hatch. We’re D’s more abundant?
Edit:
I am pretty sure the pictures I posted above are C or D hulls, lack of Turret storage bins, and I think I can make out the hatch doors opening up and sponson stowage bin on the driver side. Serial number ranges appear to put them in the D hull range
Keeping it simple, I may build the 5th RTR one instead of the welsh guards. Anyone have a photo of it in theater?
Can either of those marking also be used with the hedgerow device?
I thought he looks way more like this guy…
ya falla…?
Ryan, I couldn’t specifically say that vehicles from either of these units ever used the device or not, but I would be wary of such. As far as I can discern not may Brit tanks were fitted with the device - it was also a specific solution to a specific problem. Once clear of the Normandy environment, or rather the bocage environment, they would have had no utility in any case and been discarded as soon as possible.
It may be that pics showing Brit tanks, specifically a Cromwell thus equipped, may have been a trials vehicle. That said, I seem to recall seeing a pic of a Churchill fitted with the “prongs” as they were known in Brit parlance.
Thanks for the information even if that is really what I wanted to hear.
Yes Tim I definitely see a resemblance to Robert Shaw!
I just need to emphasise Ryan that I’m no Normandy expert but Brit use of the device appears to be sparse.
I am still overseas and can’t access my references, but the main differences between C and D are the engine deck and the hatch on the hull top. You could load the engine deck with stowage and a tarp to cover that, as an easy solution. accurate Armour did a replacement deck, or you could try and fill the incorrect hatch cover separation lines, remove hinges and handles, etc. The triangular hatch and hinge mods for a D would not be too hard to scratch build. There is a 3d file on Cults3D you can buy if you have access to a 3 D printer.
In regard the registration numbers, the ones to fit the Tamiya hull would be in the T189 and T190 ranges (hence the T187 in the kit are wrong markings for the type)
The F type had the side opening second hull hatch, and as this meant the stowage box as per earlier types had to be removed, additional boxes were added to the turret during construction.
If I recall correctly, the D type was the most numerous in active service, the F started to be issued in June 1944 - but do not quote me, as this is memory, not from checking my sources!
Also, Cromwell made by Vauxhall had a special one piece hatch.
