Are there any other tapes besides Tamiya? Tamiya tape isn’t sticky enough.
I usually use blue painter’s tape.
What are you using it for? I have used the blue and green painter’s tape but found it left adhesive residue on the model, almost like a glittery sheen.
Do you lay the tape down on something first to remove some of the tackiness? I usually adhere it to the underside of my forearm and then pull it off to put on the model. It doesn’t stick as strong and should leave less residue. I also use 3M brand which might be better quality than a more generic brand.
Avoid the orange tape at Hobby Lobby at all costs–does NOT want to stay put.
The only answer I have is… “tape stash.” I’ve accumulated a collection of different brands for different jobs. There’s a lot out there — just need to experiment.
This is what I do as well. I use generic painters tape, and I’ll stick on something clean and smooth like a kitchen counter top a couple times and peel off, it reduces the stickiness to the point it can still stick, but also doesn’t leave residue
This is the answer /\ /\ /.…
Tamiya tape (n multiple widths), blue painters tape (with a piece of glass and new X-acto blades to cut on), automotive pin-stripe tape (in multiple widths), even cutting the sticky edge off of Post-It notes. All have their places.
I use masking tape that you would use in the house when you are decorating.
