The Great Decal Coverup... Or Not ⭐️
I was just wondering if anybody has ever done this successfully: cover a small WWII US Army star decal with a larger one?
I already removed a very tiny kit provided star and replaced it with a larger one from Dragon that I had in the stash. However, it’s still not the size I was actually looking for. And I’d like to avoid going through the messy three R’s… remove, repaint, replace all over again. Ugh! So, I was thinking of ordering a decal sheet from Archer Fine Transfers for a possible coverup.
Image No. 1: Dragon replacement decal. Image No. 2: Preferred size.
. US Diamond T 968 Cargo Truck star
Or maybe, I should just count my lucky stars? … Oh yeah, that pun was intended! :joy:
Thank’s in advance! :star:
—mike
I guess as long as you sand down the first decal lightly you should be okay, as long as the Archer decal is fairly opaque.
Mike, If the new star you want is larger, can’t it just be placed on top of the existing smaller one(s)?
It depends on the opacity and what you want.
You have a dark back ground with a small white star, a larger star will conviently go over the smaller star however, the white smaller star may be seen through the larger star because of the contrast between the base color and the smaller white star if the larger star doesn’t have enough opacity.
You can try using some tape to pull the old decal up. After that, it would require very little clean up. Burnish the tape down over the old decal, then peel it off.
Ken.
I second Ken’s tape method - I’ve done it accidentally with decals I wanted to keep!
Hello all, Thank you for the replies!
Monty Python script:
This is not the Removing Decal Department.
This is not the Decal Replacement Department.
This is the Cover Over Decal With Another Decal Department.
Refer KitMaker Topic: “Removing Decals”
My question: Have you ever covered-over an existing (in situ) decal with another decal? Were there acceptable results or were there adverse effects?
Fellow lurkers, you’ve left me no choice but to perform the “medical experiments,” myself… I had Igor go out and dig-up (order) the ‘U.S. National Insignia for soft skins’ set from Archer Fine Transfers. The plan is to spray-up a sheet of styrene, paint, gloss coat, blah, blah, blah. Then, I’ll lay-down one of the older Dragon star decals… MicroSet, blah, blah. After which, I’ll overlay the new (larger) star to witness the outcome. Stay tuned for my report… :memo:
Cheers!:beer:
—mike
If you cover over an existing decal, you will almost certainly see it to some extent. You may see a difference in color of the new decal, and you will see a raised area where the old decal is. If that is the effect you want, great! some vehicles do have new markings applied over the old, with some amount of show-thru. Covered up white stars on WWII Sherman tanks is probably the most common example of this.
Ken.
Perfect… now just imagine John Cleese screaming that at some unfortunate person.
Now there’s an interesting thought. … Ken, consider yourself added to my legal team! :books:
—mike
The following decal overlay trials were conducted in my infamous ‘PanserWerks’ laboratory.
(Note: No US Army vehicles were harmed in these experiments).
Chemicals in order of appearance:
• Vallejo Olive Drab Primer (73.608)
• Vallejo Gloss Varnish (70.510)
• MicroSet Setting Solution (MIC-1) (blue label)
:star: TEST No. 1
As can be seen, the Mirror Models decal is visibly more opaque than the overlapping Dragon decal half-segments which easily show through one-another.
On a side note: I needed to work more quickly moving the Dragon decals around, as they became weakened under the MicroSet solution.
:star: TEST No. 2
Test No. 2 illustrates that ‘Archer Fine Transfers, Nano Film Decals’ have a very similar translucency to the Dragon decals. And although more durable, they seem a bit more grainy in appearance.
:star: TEST No. 3 (left) and Test No. 4 (right)
Test No. 3: Simply one Archer decal over one Dragon decal.
Test No. 4: Two perfectly aligned Archer decals over the Dragon decal. Even so, the Dragon decal is quite clearly showing through. … :thinking:
That’s my conclusion and I’m sticking to it! :laughing:
I hope this was of some use to fellow modelers.
Cheers! :star:
—mike
Careful, you may end up in a sticky situation!
Ken.
Could you, using archer transfers, place one star on top of another, doubling the opacity?
Now there’s an interesting idea. … Greg, consider yourself the newly appointed Director of TOOBA (Thinking Outside Of the Box Agency).:bulb:…
Later on …
Subsequent to Test No. 4 fail, I’m demoting you to one star! :star: :laughing:
—mike
Thanks for the tests, it is good to know that in general covering one decal with another is not going to work (unless you want to show that)
For other reasons entirely, I have had to put a second (same sized) star decal right over the first (to improve opacity).
If your smaller star shows thru consider putting two large star decals on your model. One directly over the top of the other.
As seen here; I was not happy with the strength of the white color in the star decals and I had a second doner kit so I put a second set of stars directly over the first. Then sealed it all in with Future Floor Wax and a clear spray top coat.
