The real deal - what filter for diorama soil
Hi folks!
For those of you who use real garden soil in your 1/35 dioramas: What mesh size do you use to sift it? Or would you rather purchase already sifted soil?
Thanks to everyone :slight_smile:
If you’re going to use real “dirt”, it might be wise to thoroughly micro-wave it to kill any organisms (animal poop, fungus spores, mold, etc) that might grow.
:grinning_face: :canada:
Two sieves of different sizes. Found “ground material” is free, and much more interesting than store bought. That said, depending on your project, there are several commercial ground material products than can complement the stuff from your garden.
I rinse, let dry, and then bake all found organic materials. My backyard is a forest full of fungus, ticks, molds, animal excrement… painting a charming picture here… it’s great, you just have to be honest about what you are harvesting to bring into your house.
Thanks to everyone so far for your answers!
I did clean it and I think I sifted the soil pretty well. I spread the soil evenly and thin on aluminum foil, misted it with water and baked it for about 30min at 240 degree Fahrenheit in the oven. I am pretty confident that I can use it.
I am just wondering what mesh people are using for 1/35,
No issue with previous contributors, and clearly you’ve sieved down to a very good grade. It’s the next step that needs exploring. I doubt you’ll distribute the soil dry (?!), I found that mixing in a fairly dilute solution of PVA (around 60/40 with water) allowed for some sculpting without the result going shiny. In other words it should set where you want it.
I don’t use real dirt at all. When Celluclay dries, it has a naturally “grainy” surface. I also sprinkle a brand of unused kitty litter (I don’t know the brand as I got it from a friend) onto the fresh Celluclay. When thoroughly dry, I use a thin black wash, then dry-brush:
Diluted PVA is THE go-to. No arguments there. But…if you happen to have a bottle of matte medium hanging around it is an excellent alternative. Drys rock hard and dead flat. Depending on the application, I have used both on the same dio with success. The difference between the two kinda falls in the catagory of “same but different”. Experiment! Happy tera-forming.
That looks amazing and varied by the scene. Maybe not cheaper than dirt, but it looks just as good if not better. Unless you have a huge area to cover like a model RR, it seems a simpler way to go.
You can save yourself quite a bit of work by using sand blasting medium, available in several grits. Pre-sifted. No baking. Although you do still need to paint it afterward.
