Hello there. The title of this post might seem weird, but bear with me.
The AK Interactive book “Buildings in dioramas” shows a technique to transfer ink from an image printed on regular paper onto the wall of a building (see picture). I find the technique very interesting but the method is not described with enough details to be reproducible (not by me, at least).
Has anyone ever tried it and could elaborate? Or could somebody with more diorama brain cells than me make an educated guess as to how this technique would work and the steps to be followed?
I don’t know the book, but in the 70’s there was a product called Decal-It that did exactly that. You brushed it on and it would transfer the image. These days Michael’s or Hobby Lobby has similar products - Products like DecoArt Americana Decor Image Transfer Medium or Liquitex Matte Gel Medium, or Modge Podge Photo transfer mudium bond the ink to wood or a clear polymer skin so you can wet and rub away the paper backing. They do the same thing the old Decal-It did. By the way, back then it was a failure of sorts - I wanted to make my own graphics for the AMT tractor trailers I was building, but the stuff wasn’t designed for that.
The lower left image looks as if the paper is being rubbed off with an eraser.
My interpretation, which can be wrong, is.
Glue image to wall using some medium or glue
Soften the paper using something “wet”
Use eraser or something to rub off the paper
Enjoy the result
The image would need to be a mirrored image.
I would presume it needs to come from an ink-jet printer (could be wrong, see post by @Dioramartin below → use laser printer)
Curious – when I tried this after printing it on a home printer on ordinary paper (as per the example), as soon as any fluid was applied the colours ran like Usain Bolt.
I was applying a much reduced 1:35 poster so eventually just stuck a reprint on the wall and sanded it. I may be mistaken but the illustrated technique looks like for a mural i.e. painted on the wall, not a poster. If so, I might sand the back to make the paper ultra thin & encourage holes & scrapes, then glue it (sprayed contact adhesive) to the wall and then very gently sand the front, and finally hope a quick sprayed flat varnish didn’t ruin it.
Yes, sorry, I couldn’t really find the right words for my post, probably because I don’t quite understand the process described. But you’re right, it seems it’s somewhat glued and the product used glues the ink to the wall underneath.
I think your interpretation is right. I came to the same one but i wanted some more explanation on the gluing process, as well as the “science” behind it. I guess the acrylic medium fixes the image pigments but leave the paper exposed and removable.
Alright, thanks gents for chiming in. I have Liquitex matt medium at home and will experiment sometime soon and see if I can reproduce this technique. I’ll keep you posted.
Which is why my idea in the 70’s didn’t work. For lettering at least. For logos that could be mirrored on the opposite side it worked, but way too thick, not unlike some homemade decals on this site today.
You can do a search for something like “applying ink jet print to wood” and find a number of solutions. One that seemed to be relatively straightforward used PVA glue and Mod Podge:
Apply two smooth thin layers of PVA glue to the shiny side of a sheet of stencil or transparency film.
Print a reversed image of what you want to put on your substrate on the film. Cut out the image with a border to allow grasping it.
Put a thin layer of Mod Podge where you want the image to go.
Place the film printed side down on the wet Mod Podge, pressing carefully to remove any air bubbles.
Allow to dry for 24 hours or more.
Carefully peel the film away; the image should remain stuck onto your substrate.
After watching a couple videos, I applied Liquitex Matte medium on a test surface and pressed a small print (from my kids drawing box) on it. Waited overnight for it to dry and used a wet sponge to remove the paper. I’m rather impressed by the result of such a simple process! Lots of possibilities!
Just basic laser print in black on regular paper from school. Nothing fancy at all! From the videos I watched, and as mentioned by others above, it needs to be printed on a laser printer.
