New forum, new build log. I’ve been building Trumpeter’s 1/35 9P140 BM-27 Uragan. Got sidetracked with two campaigns and home renovations, but now the bench is clear and the work on the house is slowing down, so time to pick this back up.
I didn’t fully document the early parts of the build, but I gotta say I like the kit. The chassis is definitely something different, and everything went together well. Maybe one day I’ll do the Frog-7 too.
There’s been a lot of painting between build steps as there is a good amount of the chassis visible when complete, so a lot of piecemeal painting & weathering. With the chassis mostly done I got started on the engines, decided to add some wiring. References are hard to come by, but from what I can see it looks like a complete rat’s nest in there, so I only added what I could make sense of.
Then I painted them and dirtied 'em up
With the engines done, the instructions have me moving on to the cab. Lots of instrument panels in there. Like the engines, I want some more detail, so I’ll be adding some wiring. I also didn’t fully follow the painting call outs in the instructions, instead I used picture references I found online.
I didn’t get the decals perfect. They come in clusters, which can be hard to fit when there’s surface detail in the way. Took them two coats of MicroSol to get them settled down.
In the meantime I’ve been weathering the chassis, oils, chipping, pigments, etc…
And that’s where I’m at so far. Current plan is to keep plugging away at the cab, in the end I want to pose it with the doors open.
