Quick Call-Out Chaps: 1962 Boots - laces - “ladder” or “crossed-over”?
‘Grateful you save me from a Google too far!
Whilst I’m (lazily) awaiting a response re laces - I thought I’d better crack on with the base. As you can see for a tarmacadam-type road, I use a blast of Rustoleum to get an effect - not immediately discernible in 1/35, but seems to me about right:
I’ve also added some scenic affects from the model-railway fraternity to depict the grit and detritus that build up at roadside edges.
I’ll probably rattle can the whole shortly to vary the a grey a little. Further tank-deposited crud might be installed later once the vehicle is in position.
And in case you’re getting a tad bored, a reminder of the plan:
I would just use white decal strips for the helmet. You may not have a white decal sheet, but I’ll bet you have white decals you can chop up, i.e. numbers on Soviet tanks. As for the boot laces - ladder for parades, high visibility events (like guards at Spandau) MPs in Class A’s - in fatigues not as often, although I’ve seen it.
Right, thanks; I’ll probably go for “ladder”, though it means a faff with endless stretched sprue; there again, an equal faff tinkering with etched brass mesh which was my possible solution for “crossover”. Anyway, nothing I haven’t done before!
(from my JOC Land Rover project - seems a long time ago now)
I changed my mind! In the end I decided to go with the etch option, just to experiment really, but I think it gets an effect; I’ll need to sand down gently to blend in but I think it will do.
Sling for the M3 installed on the shoulder – arm omitted at this stage to facilitate painting, but I’ll have to sequence this carefully – which is often where I err(!)
Silly me, I forgot that you making him as an MP and not a real combat arms field soldier
Yes, the glossy helmet with the proper distinctive markings are in order.
And a bit of concurrent activity while the figure dries in primer:
Next stop for the base will be a bit of texture for the grass verge.
The MP figure in primer; a but clunky and crude but about the best I can muster; hopefully the paint job will conceal most(!)
Quite a bit of effort to be honest but an effect is needed to offset the mighty M48 rumbling by I think. Obviously a singleton as opposed to the vehicle and grouping of the original idea:
Last instalment today Folks (sigh of relief all round I should think(!) - the base: I’ve added the tiling grout I usually use to provide a bit of terrain, hopefully to be covered in static grass tomorrow - though getting it actually “static” is often a trial:
I really enjoy watching your figure transformations take shape. I change the position of an arm and how a hand is, and think I’ve been creative. I then come on here and feel quite inadequate ![]()
Well, I still think I’ve along way to go - but not sure I’ll get there(!) - but thanks anyway.
I don’t mind tackling this sort of thing; I did it before quite extensively when I modelled what felt like half the East German Army (on my Berlin Wall Munga project). This was just one figure, but all his personal equipment either had to be made or borrowed, most actually made and I’m no sculptor really. I can bulk out a smock or two, but straps and webbing are tricky. As I say, paint will conceal a lot of imperfections - I hope - starting tomorrow I should think.
Hi Brian.Just catching up with your creations.The M48 turned out excellent to my eyes.I know you were concerned about the colours and it turned out great.The diorama is coming along great.I use Rustoleum texture spray and its great for anti slip coats on tanks.Im hoping to get back to my 2 Leopards im working on today.Happy modelling.
Richard
Thanks Richard.
Two Leopards? That’s ambitious stuff - or rather - would be for me. ‘Hope they’re going well.
Today - could be more figure hell - or rather, the painting stage. We’ll see, and I’ll report back(!)
Fantastic progress on that figure there, Brian. The Tank Museum modellers have been nagging me lately to do some figures with my builds, so I need to take a bold step for me and do something about that.
Thanks Terry; well, get cracking then! Start with Valkyrie or similar - a ready fix - if I may make a suggestion - that way it’s a sort of easy break in. For modifications to represent what isn’t’ available commercially, well, welcome to my Cold War hell(!)
Fantastic job all around Brian, the tank , figures and base are just fantastic. I need to pick up a can of that concrete effect stuff. Looks great
Hi Brian.
I started the oldie Italeri Leopard 2A4 a week and have done a few tweaks already.They moulded side lockers etc on top of the sidekirts with the result trying to glue them to look neat is tricky.I cut the bits off the sideskirts gingerly and stuck them on the hull side.Some got a bit damaged but can bodge them hopefully.The hull top and bottom isnt a great fit and i made it stronger and more gluing area by making some plastic shelves under the turret ring etc for the hull top to glue securely to.The other Leopard is an Italeri 1A5 backdated to the 1A2 and will be an Italian one from the 1980s.Something different and colourful markings.Good luck with the figures!!!.
Richard
Now that is interesting: I have the Revell Leo 1A5 half built to make a What-If Leo Sturmpanzer (don’t ask) but I got distracted by the recent to-ing and fro-ing on here about Canadian Leos - so now plan to turn it into one of the “Rent-a-Panzers” they had in the mid 70s. A simple enough recover with what I’ve built so far but I also have the Perfectscale Modellbau specific 1A2 turret en route - so I’m looking forward to that.
In the meantime, thanks for the support re the figure. At it now!
I forgot to ask, presumably your Leo 2 is going to stay as an early type?
Hi Brian.Yes my Italeri 2A4 will be an early one but im not sure what type the kit depicts.Ive started a build on here earlier.It goes together quite quickly as it hasnt mountains of sprues like Meng etc.Tracks are floppy rubber and 4 joins each length.Ive finally gotten round to getting a Meng Leopard 1A3/4,Ive bought a Danish Albino Leopard conversion by Legends and a late Canadian C1 conversion.I tend to build a few kits and have a mass primer and paint session.
Richard
