USAREUR M48A2 - c.1962
Thanks Carlos - I have similar - but just wanted to make certain. I will try and depict the texture ie those “panels” showing through the canvas with very thin paper covered in Mr Dissolved Putty, which might work, though arguably in 1/35, not essential.
Anyway, at least I now know which way is up!
Tamiya’s 1980s US infantry set and the expanded Gulf War version come with very good gas mask carriers. They’re also useful for ALICE gear in general.
They do indeed; that said I found the figures and their kit a bit weedy. I have the 2 x sets they did but given that they’re up in the attic, I couldn’t be bothered (that’ll be on my tombstone one day).
Whilst I find making modifications to figures with Magic Sculp and the like a bit tricky (see above!) I don’t mind cutting up chunks etc to turn into say, ammo pouches. Just don’t look too closely. But then, what else is a Cold War modeller to do when it comes to figures?
Thanks anyway Jakko.
DML US Marines comes with four of these gas masks
https://www.super-hobby.es/products/U.S.-Marines-109135.html
There was another DML set (US Rangers) that I got M17 carriers from. I was hesitant to use them given the fact that many older DML figures were closer to 1/32 scale. But it turns out with a side-by-side comparison that the DML ones are nearly identical to the Tamia ones from their infantry set.
I’ll go with what I started; as I said, I don’t mind too much having a stab at equipment with Magic Sculp or whatever. It goes without saying that the information on this site is vast, and generally proffered by very helpful people.
Well, not much to report today; I’ve added more details to the MP figure - the grenade loops on the ammo pouches being the most taxing.
The Tamiya Weapons set arrived, so I selected the M3 SMG, and in fiddling with it, trashed the stock. I replaced this with brass wire, a little overscale but then, so was the plastic version. A fairly clunky join I must admit but will probably not be that discernible when fitted.
If you’re wondering about the mismatch with the weapon and the ammo pouches, then one of my source pics shows this arrangement. I also intend to fit a bayonet and scabbard to the figure, again, as pics prove that the M6 presumably, given the timescale, was a very versatile knife in any case - or - perhaps the wearer just wanted to look dangerous(!)
I hadn’t originally planned on depicting a butt pack, but my poor modifying identified quite a gap between belt and straps, so I fashioned one tonight - shown below incomplete - and will need to cure overnight. I will use foil to furnish a flap, and strapping - also shown ready. I’ll use the same for the M3 sling. He’ll look a bit better kitted out to be honest, after all he is on exercise, and slack drills will not be able to stem an onslaught by GSFG in the fraught days of the early 60s!
Turns out I have both sets…so 8 pieces. if it is not overseas, if You @BootsDMS need it (and you are in Europe), i could send it next week (i have to search for it). Shipping to US would cost much, and as of recently, Post office requires open envelopes and don’t guarantee shipment. I found that the hard way - don’t know whether my donated T72 tracks reached the destination.
Send me PM if in need of those!
No but thank you for the offer; I am perfectly happy to continue with my home-made pattern - that way I become accustomed to using Magic Sculp and improve(!).
However, thank you again.
Well, it’s taken me most of the afternoon, but what else is there to do on a wet February?
Just about finished the construction phase on my US MP figure. A touch of blending in with some light sanding, and Mr Dissolved Putty, then install the arms and that’s about it I think.
In addition to the M3 SMG, I plan to have the figure holding a folder and mapping in the other hand, manifests, convoy timings, and all the sort of stuff that MPs deal with. People sometimes forget that MPs aren’t just there to knock heads when necessary, but are also vital in route planning and exercise control, or that’s my experience in the Brit Army.
Anyway, I’m pretty sure he’ll look OK alongside the tank. Once I’ve done the above, next stop primer – which will show just about every flaw there is!
Fantastic work Brian!
Well, thanks Richard; I’m not too sure it’ll hold up under scrutiny, but I’ll see what it’s like in primer, mind you, there’s no going back I assure you; a reasonable paint job will help disguise the worst - I hope.
Of course, this all represents the dilemma of the Cold War modeller - figures - or lack thereof. It’s also only just struck me that, with a change of of weaponry, this figure would also serve in a 70s diorama easily enough.
A lot of work, but then, has to be done!
Looking real good! I would suggest adding a helmet cover. About the time the M1956 gear was introduced, so were issue helmet covers
I really enjoy the methodology of how you do your figures,
looking frwd to the completed project.
Dave :slightly_smiling_face:
Well, I can only assume that MPs would wish to be identified as such; this is the fellow I found - also in Life magazine:
Whilst I can probably find a decal for the lettering, a helmet band will be a bit tricky to paint - I suspect the one here is in red, but I might go with white:
Paint the whole helmet white or red.
Mask the band and paint the rest of the helmet
I think it is easier to cut one strip of masking material
to an even width than trying to align two strips at a
uniform distance from each other around a curved surface …
The old Tamiya MP set (one standing, the other on a motorcycle) had the helmet markings that you need!
Thanks Tom - but not in the stash; the original markings I got with the donor kit for the figure did have some, but look beyond use:
However, I hope to use what I can find on the Perfectscale Modellbau US bumper codes sheet - which is what I used on my fairly recent JOC Maastricht project on the Belgian MP’s sleeve:
so if I’ve enough left, they should work on both helmet and sleeve.
Good call Robin - I’d forgotten that; with that methodology I might even go wit the red - or at least that’s my interpretation of the picture - a splash of colour wouldn’t hurt in this olive drab world(!)
prime with grey, then white and then the red.
Grey can be omitted if the white has good coverage (rare ..)
