USAREUR M48A2 - c.1962
Looking real good! There is so much subtle variety in OD, that this version falls well within the standard range.
Working on the base isn’t a haphazard operation. I feel it needs a bit of care in the composition. In a way, my hand is forced to do this by the very size constraints; that is, for say, a single large-ish MBT, I’ll use one of my A4 (the European standard paper-size) bases. These are produced locally via my nearby model ship in Salisbury – 12mm MDF.
They’re not especially cheap but this way I can dictate the size and format to a consistency, as opposed, say, to those who perhaps use picture frames – not that there’s anything wrong with that; I just feel a base, of whatever sort, helps display the model a little bit better. It doesn’t have to be a full scale diorama, but just to set the model in context.
So, as mentioned above, in this case it’s going to be a simple German road. First though, I sand down the edge so that they’re smoother – a plain cut MDF edge un-sanded just looks wrong and crude when stained/varnished or even painted.
It takes several coats and a fair bit of sanding down. I finish off by using a clear varnish.
I constantly check that I’ve got the composition right; of course, there’s not that much room for manouvre given that an average MBT will pretty much fill the base, but I like to try and get it right. The details matter I feel, remembering that the Germans drive on the right is one.
I think in this case I was more pleased with the German sign than I was with completing the kit(!)
The rectangular piece of aluminium is merely my template for the engraved brass signs I fit to my bases.
Everything looks great.
Looking good! One little detail that I noticed. The yoke portion of the D handled shovel in the pioneer tools is made made of metal, with a wood cross member.
Thanks Carlos - an easy enough fix!
My local hardware store (and, I assume, other people’s local hardware stores too :slight_smile:) will saw wood, MDF, chipboard, plywood, etc. to any size I want and only charges for the number of square centimetres of material actually used.
I’ve deliberately shown the figures of the crew here; I haven’t started work on the MP figure just yet. I do this, not to show my craftsmanship – or rather lack of it – but just to exemplify the sheer effort that has to be put in, to modifying figures suitable for the Cold War. True, manufacturers like Valkyrie have filled the gap up to a point (though hardly any prior to 1960), and for the other side of the IGB, Minart seem to have cornered the market in Sov crews, but in this instance, though the Valkyrie “Modern US Tank Crew (In Europe-1970 Era” (sic) would have been a suitable shoe-in, even they are minus cabling, binos and other stuff. So, whilst a deliberate choice, perhaps I shouldn’t be moaning, but as I say, I just wanted to show what needs to be done to achieve a half decent figure for this 1960s M48.
No mikes yet fitted on the T56 helmets.
The additional figure is actually for my M59 APC; note that I’ve used a WW2 Hornet Head sporting the WW2 helmet, but have filled the holes in using Mr Dissolved Putty, and added a boom mike from a length of fuse-wire with a blob of the putty on the end for the actual mike. He will be the Driver figure for the M59, and only his head will be showing in any case; I haven’t yet thought about a Commander figure for that project!
The tank and crew look great so far. Very nicely done.
Too bad there’s no Elvis figure to go with it! Ha ha Wayne
In addition to the crew, I need one extra figure and that will be a US MP standing at the road junction, next to the sign For this, I’m using the ancient standing MP figure that comes with the original Tamiya Jeep kit, which historically if you like, is the right and proper destination:
I’ll bring him up to 1962 spec by modifying the jacket to the M51 type, add 56 pat personal equipment, and will probably arm him out with an M3 SMG. A Hornet Head will be necessary. So, with all this in mind, let the sanding begin!
Which after around half an hour, gives me this:
That’s enough for this evening; tomorrow, I’ll have a Magic Sculp session:
A couple of coats of gloss varnish and we’re nearly ready to add the scenic stuff to the base:
Plus, as I miss the power of the rubber stamp(!)
Further progress on the MP figure; an attempt at M56 personal equipment, and a modification to the jacket skirts - all to be sanded and trimmed tomorrow after a night drying out. Further details to be added as I go:
A quick figure update; still some way to go. Note that most additions shown in white card are yet to be sanded down to enable them to blend in a little more:
Have I got the M17 respirator orientated correctly? I understand it was fixed to the belt - or at least appears to be in some refs - and secured with a leg strap; grateful if someone could confirm Yea or Nay.
Not I admit, a shining example of the sculptor’s art, but about the best I can do(!)
Some details still to come: the securing straps on the sides of the pouches, a few buckles here and there, the jacket waist pockets, and an M3 SMG - which should arrive tomorrow. Oh, and some boot-laces.
That’s it for now Folks.
The gas mask bag had 2 straps a long one and a short one . The long on went around the waist and the short one went around the thigh.
I’ll borrow a photo from my Berlin Wall Patrol Thread:
You can see how it hangs on its own waist strap - not connected to anything else. Leg strap was optional - it prevented the carrier from flopping around while running, but made riding in a vehicle very difficult.
Thanks, just what I needed.
Thanks Steve - all grist to the mill!
