Various Sherman Builds
My first Sherman build the 1990’s era 1/35 Tamiya M4 was more fun than expected last year.
Decided to add a Sherman build thread similar to my panzer threads. The thread will focus on simple out of the box building with minor aftermarket upgrades on occasion.
Joined Shermania-2025 Campaign with Ryefield’s new Sherman M4A4.
The kit was just too cute looking to leave in the stash…and I’ll admit Ryefield’s box art sold me the kit. With vehicles from five nations covered the RFM M4A4 offers a refreshing variety of possibilities. It’s one of those kits that eventually might merit another build one day due to diversity :thinking:
Decided the tracks look monotonous to build so started with those. 83 links per side and it’s well organized by Ryefield with 2 trees of parts per tracks.
Both tracks require ~660 parts wirh each link using 4 parts. I found Revell’s Contact Cement excellent but difficult to control with needle :sewing_needle: always getting more than desirable. Returned to my stalwart favorite of LC’s, Testor’s Liquid Cement in a Tamiya bottle.
Awesome
It will be fun to see your progress!
Oh yeeeaaaah, another Wade anothology build thread!! Always fun to follow.
Model on Wade! I’m glad the Sherman bug bit you!
Excellent choice. :+1:
I’m sure that you know about this site- M4A4 Sherman production variants
Dan, thank you. That’s the first time I’ve seen that site. Much appreciated :clap:
To everyone thank you for taking time to look, the comments and support.
Found a few pictures of a track link like the kit has. Apparently these are T-62 tracks.
More track info- Sherman tracks types
Calling it a good hobby day today wirh 330+ parts going together. The two tracks took about seven hours.
Happy the most boring :sleeping: grunt work is wrapped. Tomorrow’s excitement, the second boring part of the build road wheels!
On the brightside a Sherman has 12 wheels not 32!
Great start.I love the finish of the Tamiya M4.Looks nicely weathered.I must get the M4A4.Well knowing me about 5 maybe.A direct vision version would be most welcome.
Watching with interest.
Richard
It’s always a relief to get the hard part out of the way. Interested to see how the RFM kit goes together. Heads up, the barrel is around a quarter inch too long.
@dwnrng44 Kevin, thanks for the heads up on the barrel. I think with the tracks at ~660+ parts plus suspension & gear at ~140 it’s about ~800 parts to get to the fun!
Box looks pretty empty wirh those ~800 parts out of it for tracks & suspension!
@Richard50 Richard, thank you. I could probably see building another RFM M4A4 when time allowed but will look for 3D snap together tracks for the next one! :wink:
Found the RFM suspension bogie instruction step a little too unnecessarily complex which make the sequence fiddly for my personal tastes…some folks might like the kit guidance so YMMV.
…so Kali-Kat & I reinvented the wheel…we like to do between attending flat earth conventions (j/k)
This is probably the wrong way to approach the issue (Sherman ignorant) but it worked for me. Build the wheel subassemblies and clean up the parts needed for one sides bogies.
Tack J29,J32 & the metal springs all together with liquid cement. I was too lazy to open the CA.
Glue J30 & J26 together with return roller slid into place. Squeeze and let the liquid cement set briefly.
Place two J17’s as shown on the subassemby with the springs. Note arrow that tab snaps into housing.
Click
Snap in wheel subassemblies as shown in instructions.
Add skid
When it’s all cured tomorrow, will clean up missed mold seam spots and do other quality control tweaks.
Cheers :beers:
Don’t forget to drill the four holes in the front!
Looking good. Might have been easier to clean the top of the bogie before adding the skid (j16).
Wondering out loud why there hasn’t been an evolution of bogie housing construction from manufacturers. They did with the bogie wheel faces. Seems instead of having a middle join, why can’t they have the part match be on the backside of the housing. Added the four holes on both sides. Make the return wheel bracket separate parts for the three different styles and attach using those same holes like the 1:1.
Ryan, thank you.
I like your idea on how to mold the bogies halves. That’s an ingenious solution that would make modeler’s happy!
I wonder if RFM was concerned wirh creating short shots or would have needed a slide molding? Be pretty slick to slide mold and put the holes in the end @Dan mentioned!
Out Asuka, Asuka & out RFM, RFM in the next generation Sherman kits :wink: :stuck_out_tongue_winking_eye: Hey, @Takom, there’s an idea for the SuperBlitz Sherman kit we’d all like to see.
Making the ends two separate parts might have worked too but it’s already a complex bogie assembly at ~20 parts.
The top is very clean as designed. Makes one wonder why they didn’t do the sides as you mentioned :thinking:
The red shows where the top goes together. If the green had been extended, it would almost be molded as Ryan suggested and be much nicer!
Instead the one end has an L shaped seam the other is straight.
The seams are fixable with the wheels snapped in place. My preference is fixing after the spring assembly is seated. I’d probably pop the seam snapping the spring assembly in place since it mounts higher :laughing: :rofl: :joy:
This build is definitely an adventure out of my model building comfort zone…may need a Panzer Police Approved Safe Spot…ie sit in the closet w/the Panzer IV kits! (J/k)
It’s okay Wade, the Sherman Sheriff is here…
We won’t let you go astray.
I don’t like how those are joined at all. Looks like a pain to putty and clean up.
Asuka’s is easier to clean.
Matt & Dan, thank you.
Sherman Sheriff’s good idea! They’ll ride herd on unfounded “experiments” like Chinese Zimmerit or The Beijing Special M4 w/S mine launchers.
What’s the British equivalent? Cromwell Constables? Spanish one is obviously, The Inquisition but no one ever expects them to make an appearance.
There’s an Auska Firefly in the stash, maybe that will be the next Sherman project. Make a nice comparison.
