Wanting to improve my skills
Ok thank you I will need those. I have got many cuts and glued my fingers by accident many times. once with krazy glue that stuff works well at sticking I had to put my blade in between my fingers and it came off. It glues so fast too, under 10 seconds.
Kirkland brand gives you the most ā€œGloves for the buck.ā€ But do shop around for whatever brand you want and the shipping date…many brands to choose from.
https://www.amazon.com/s?k=kirkland+gloves&ref=nav_bb_sb
Ok, thanks for the advice!
I do have one thing on my mind that has been nagging at me. How do I preshade? Since I’m good at airbrushing.
All this time.
Who knew?
I had a scary almost cut moment my hobby knife rolled off the table and I almost did the reactionary leg flinch to catch it then remembered what was falling and just let it go. I don’t want to make the news for cutting my femoral artery in that manor.
Thats happened a couple time to me. i cut my hand up doing that. learned my lesson
You add a primer and/or secondary color to the model and then your top coat color.
Might look like a white/grey primer base coat, a black/dark color for the panel line/recessed area, then a thinned top coat of olive drab for instance.
The thinned coats allow the base/recess color to ā€œchangeā€ the appearance of the top coat. You don’t get a single uniform color look across the model. It has variation.
You can also post shade by making the top coat color lighter and only spraying in the center of a panel.
Then add washes etc to tie it all together.
ok, thank you!
Yeah, absolutely who knew? I’ll see your multiple scars and raise you…
That was from a brand new blade 30 seconds old, but I was so glad I avoided slicing through a glove :upside_down_face:
Ouch. That’s what my original cut looked like from thirty years ago. I was slicing a brake detail off of a loocomotive with a chisel blade. It went throught the body of the loco, and all the way into my finger. I held it above my heart while squeezing the hell out of it for about half an hour, and then glued it shut with CA. Could have ben worse, but it still has a weird numbness sometimes to this day.
Amazon sells cut-resistant gloves. I never bought any because I seldom use a hobby knife these days since I work with resin and often use a razor saw underwater.
Many cut-resistant gloves to choose from. I guess it all depends on how ā€œAccident proneā€ you are since the cut protection levels vary from Level 5 to Level 9, and they’re not that expensive. Some of them probably won’t stop a knife poke, but they’ll most likely stop a cut if the weave is tight enough.
https://www.amazon.com/s?k=metal+knife+gloves&crid=23E0WTJF7H5W&sprefix=metal+knife+gloves%2Caps%2C158&ref=nb_sb_noss_1
Those gloves look like butchers gloves
Maybe just a tad clumsy for modeling …
Who says modellers don’t have first aid equipment on hand 100% of the time.
At the cottage and home I always have a bottle of Gorilla CA glue and quick-clot on hand for cuts. I once had get 5 stitches in my finger while cleaning the kitchen mandolin blade. I used cut resistant gloves while using the mandolin, but who would have thought to use the gloves while washing the blade, d’oh!
Likewise ouch & numbness – and likewise clamped it with other hand for 30 mins. Added problem was my haemophobia, so everything went dark, cold sweat, luckily wife was present to stop me passing out. Quite a sight, head between legs & arm in Hitler salute. Wish I’d remembered the CA fix, better than stitches?
Well it’s certainly better than giving them to yourself. :rofl:
CA works extremely well. While it was not originally designed to, it was used extensively during the Vietnam War to close wounds. Just don’t use accelerator. I learned that the first time I used it…
