Beautiful looking build, the way you have highlighted the tools etc is extremely well done. Did you dry brush them or do you have another technique?
Love it ![]()
Watto🍻
Love it ![]()
Watto🍻
Thank you Watto. It’s very kind of you to notice and comment. Painting tools
is a hurtle for me finishing a model.
My brush painting is always a mess of nasty brush strokes that look like a dying fish out of water flopped around and made. So l attach all of the tools during assembly before painting and let that determine how the tools are painted.
Securing the tools on their base for easy handling makes them easier to deal with. It’s all washes (or glaze?) and drybrushing from there.
To make painting the attached tools easy, I’ll put a drop or two of paint on the palette and thin with a drop or two of thinner to make as a heavy wash. This mix is flowed onto the item. The wash nicely wraps around the handles etc.
On tools with wooden or bakelite handles (wire cutters) I like to use a darker old wood color. Likewise for the jack block. After it dries a small wash in a few areas of the handle of a lighter new wood is applied. After its all dry a wash of raw umber oil paint and a very light dry brush of titanium white to pop the edges and details slightly.
The jack, prybars, & S hooks get diffent mixes of chain mail & silver applied as heavy washes. Followed with raw umber wash & light dry brush of titanium white to pop the edges and details slightly.
The heavy washes for basic color, spot washes for highlights, overall each and drybrush probably show up best for this Pz IV on the jack block. It all goes pretty quick despite how it reads.
I think it helps pop the detail for normal viewing distances on the model, probably not realistic etc. We may not have all seen a Pz IV or other tank in person but we’ve all seen a shovel or two up close!
I want to learn new tips to try to do tools better as they are a focal point of attention for the eye.
Apologies for being long winded.
Everyone please feel free to give suggestions and tips.
My workshop.
Gave it a top to bottom clean. Every Friday normally takes 2 hours. Worth it as I never get dust on paint. All items moved from shelves & the shelves cleaned.
Paint brush cleaning water changed.
Scalpels get new blades. etc. etc. Just a nice feeling to work in a tidy clean enviroment
Not so much modelling today, but I finished re-organizing my workbench!
It went from this mess…
…to this!
I really like the storage modules from Hobbyzone. They make it possible to quickly re-organize the set up should it be neccessary.
Erik, that’s a fantastic looking well organized work bench! A+++
Good to hear your thoughts on the HobbyZone modules. I’ve been on the verge of trying them a few times.
Nice looking build @TeeAge, it’s always a good feeling to finish up a sleeping project. As far as the 1:1 tank, I’ve never understood this design approach with a fixed gun tube, relying on rotating the entire vehicle for target aquisition. It looks smaller than I’d imagined, if you have a moment maybe you could take a pic of it along side another AFV for size comparison.
Cajun ![]()
Go for it! They are brilliant. Easy and actually a bit fun to build, The quality is very good and the fit is «Tamiya Shake and Bake». All the drawers slides Beautifully in and out. Only «issue» is the magnets keeping the modules together. They are rather easy to get the wrong way around. The solution is to build one square module and use it as a master, building the rest, testing the magnets on the master.
That’s an excellent tip!
Thank you for sharing. After I get the half dozen projects in process off my bench, I can revamp with HobbyZone.
Designed when gun stabilisation was still a dream for the future → firing on the move was essentially a way of wasting ammunition.
Statistics showed that a low profile would be advantageous. No turret → low profile.
Whipping the vehicle around was (maybe still is) faster (40 degrees per second in the Abrams?, a full pivot turn takes a tad longer than a full turret rotation) than cranking the turret around (Wittman did this with his Tigers, rough alignment with the whole tank and then fine adjustments with the turret).
The M60 turns the turret 24 degrees per second. The S-tank has relatively short tracks, only 4 roadwheels, it can make a 180 degree turn on gravel/dirt in approximately 4 seconds, gun traverse would be around 45 degrees/second (Cold war era traversing comparable to M1 Abrams, in production started in 1979?. The S-tank went into production in 1967.).
We were not going to attack over open fields, we were going to sneak up and ambush big clumsy Soviet tanks. Design started in 1956 when T-55 was the latest and greatest enemy tank. The S-tank stood a little taller than the engine deck on the Soviet tanks from that time.
Small tank large gun, 105 mm with a 62 caliber barrel length (the one on the M60 was considerably shorter). Effective firing speed with the autoloader was 13.5 shots per minut, the gunner needs to reacquire the target due to dust whipped up by the previous shot, the autoloader on full auto could deliver 24 shots per minute …
The hydraulics moving the tracks for fine aiming are just as precise as the electric, hydraulic or hand cranked turret rotation drives in normal tanks.
The S-tank started going obsolete when gun stabilisation and aiming computers became practical and common.
Strv-S
Length: 9 meter (overall)
Width: 3.8 meters with fuel cans hanging on the outside of the skirts, 3.4 meters “clean”
Height 2.14 m
M60
Length: 9.3 meters (gun forward)
Width: 3.6 meters
Height: 3.27 meters (M60A1 & A3), surveillance tower …
M1
Length: 9.77 meters (gun forward)
Width: 3.66 meters
Height: 2.44
I suppose it has merit against a static target but would be at a disadvange in close quarters engagement against multiple targets.
Cajun ![]()
Moving targets were difficult for everyone back in the 1960’ies.
Target acquisition depends on how fast you can move the gun in the right direction.
Wittman discovered that swinging the whole tank was faster than cranking the turret around.
Each and every weapon/system/vehicle is designed against the requirements set by the intended usage. We opted for a low profile, powerful gun, good protection for the crew and some other requirements which suited our tactical conditions.
This is how the Strv-103 would be sitting in an ambush position.
This one didn’t get deep enough, sits a bit too high.
Not much to see from the front, dang hard to hit and that sloping top/glacis would cause the projectiles to slide off. Not much use against a DU arrow but those didn’t exist back then.
In the later years they mounted a steel bar fence at the front to help break up incoming shells
My goodness, please don’t apologise.
The dusty and realistic appearance you’ve achieved is spot on for me, it looks right.
Thank you for such a complete and helpful reply.
Watto. ![]()
Once I saw a Gepard-Flakpanzer camouflaged with nets and wood, I had to get really close to it to see it as a Tank
Do you do home visits?
Tacoma is unfortunatly outside my business area… ![]()
Applied marking today and hope to wrap this one soon. Red 5, DAK palm tree, Wolfsangle and 15th Panzer Division markings.
I guess this is another reason to mount all our models on bases. Back here is the midwest the competition rules say the judges are not supposed to move a model. But they do anyway.
I exhibited a big truck and had the wheels turned all the way left. I got set back to second place because my front wheels had too much toe-in (in their opinion.) True story!
I actually can agree with them that the fronts DID have (just a bit too much toe-in) but how would they have known unless they moved the model and played with the steering? (The model HAD been moved considerably when I returned to the table.)
The S tank is intended as an ambush tank. A “shoot and scoot” vehicle. Especially given its’ dual front and rear driver’s compartments. It is designed for the quick get-away!
Also the electric drive makes it very easy to rotate the tank left/right in small increments for target acquisition.
