What the postman brought today (AeroScale)
Tamiya’s venerable ‘Uhu’ in 1/48. An unusual aircraft. The Heinkel He 219 Uhu (“Eagle-Owl”) was a night fighter that served with the German Luftwaffe in the later stages of World War II. A relatively sophisticated design, the He 219 possessed a variety of innovations, including Lichtenstein SN-2 advanced VHF-band intercept radar, also used on the Ju 88G and Bf 110G night fighters. It was also the first operational military aircraft to be equipped with ejection seats and the first operational German World War II-era aircraft with tricycle landing gear. Had the Uhu been available in quantity, it might have had a significant effect on the strategic night bombing offensive of the Royal Air Force; however, only 294 of all models were built by the end of the war and these saw only limited service. Ernst-Wilhelm Modrow was the leading night fighter ace on the He 219. Modrow was credited with 33 of his 34 night air victories on the type.
This is old kit now, ‘new tooled’ in 1997 I believe, but it is the only game in town at this scale. It still is a nice, relatively accurate kit though and is well supported by the AM industry.
I should have learnt from previous encounters with Aires that 90% of their stuff simply doesn’t fit the kit is is intended for and you spend hours filing, sanding and cutting with the inevitable result that you have a bodged fit that you need to cover up.
This set comes with a full cockpit but the Tamiya kit comes with a solid metal cockpit ‘tub’ which all the kit’s cockpit detail fits to. This is because the Uhu had a tricycle undercarriage and you need all the weight of the kit on the nose to balance it out, otherwise, it’ll sit on its tail. Aires doesn’t give you this, so if you’re going to use this option, you’ll need to get creative with some lead shot or something. I’m using the Tamiya cockpit, the detail Aires provides isn’t much better in my opinion and with the Eduard PE for the cockpit, it’ll be pretty nice.
I really want to open at least one engine nacelle up, as per the box art but major surgery will be required to get the Aires parts to fit (just call it a hunch). Part of the open engine nacelle concept means also fitting new landing gear wells that the Tamiya kit landing gear parts will have to somehow attach. I would put the farm on them not fitting quite right and as a result, the aircraft will sit all wonky…
Maybe i’ll get lucky… but I doubt it.
So my dilema is, do I risk screwing this all up, or do I just build the bird OOB with some nice cockpit, radar and weighted wheel bits? - and accept that I wasted my money on the Aires kit…
Has anyone used this Aires kit before? Does anyone know if anyone has blogged a Uhu build using this Aires set before?
Roly, the He 219 is still a good kit and goes together well. I have built it in 2021 and can’t remember any bigger problems with it, though I just built it oob and used only the aftermarket antennas from Schatton Modellbau on it. So I can’t tell you anything about the Aires Cockpit.
Don’t know if you have followed my build blog back then. Maybe it helps a bit. Starts from Post 43:
Happy modelling!
Torsten :wave:
I personally don’t think theres a lot wrong with the older Tamiya kits and i’d say that by the look of the aftermarket bits you have there, you’re looking at a very enjoyable and rewarding build.
Happy building :+1:
Watto.
Reading and research material.
Tamiya kits still are a joy to build.
Ok needed a dose of Focke Wulf 190 you can’t have too many!
2 kits in the box
Oh a Wildcat slipped in
And a Mirage :slight_smile:
Can’t seem to get enough Focke Wulf 190 box art either. Thank’s for the dose! :art::man_artist:
—mike
Aside from the WW2’s, I really hope Modelsvit will bring their 1:72 Mirage 2000 range in 1:48 as well!
Should keep you busy for a little while😉
Watto. :grin:
Had this one arrive from Squadron Mail Order.
Well I think I have an addiction! I think I now have enough Fw-190’s of all variants for a whole Geschwader in 1/72
And my other interest DELTA’s
I’ve considered building some Russian aircraft. But just can’t seem to pull the trigger on them…YET. I still have so many other kits to build as it is.
This 60-HR came yesterday!
Modern, Cold War or WW2 ?
What do you have in stash ?
I have a little of both, a couple of WW-2 aircrafts. 1 B-17G & 1. Corsair
The rest are cold war to modern,
X 2 -F-15’s
X 1- F-4EJ Phantom
X 1-Mirage IIIC
X 1 Mirage Super Entedar
X 1 A-10
X 1 Abrams M1A2
X 1 Canadian Leopard 2A6
currently working on the B-17G and a T-38C Talon…
Very nice !!
What scale are those ?
and from the Russian Aircraft you are planning to build, which era, what type ?
I have a lot of them in stash mostly Sukhoi, Mig, some Yak ,some Tupolev and Antonov.
There are some great kits but also others that are a real pain to build.
If you need any help let me know !
Got these two fine specimens from HLJ during their recent sale.
This is by the way the new re-issue of Kitty Hawk by a new company.
The new Ammo Mig “Atom” paint sets . HS new Ultra Airbrush .
The paint is worth the investment IMO . Sprue Brothers did a nice review of the paint as well ! Does everything Mig says it will do . Tried a few of the colors out , color match seems good .
I use Tru-Color paint mostly , but the new Atom is gonna work out just fine .
HS Ultra is a game changer in airbrushs the design makes it so easy to use . There are several videos on this that explains the brush and how use it . If your a beginner or pro it’s worth grabbing one .
I have always loved bush planes as my flight instructor was a bush pilot from Alaska back when I was getting my ticket. He shared some interesting stories about back woods and wilderness flying. A lot of hair raising moments but mostly rewarding.
I knew there were 1/72 and 1/48 scale beavers, but I didn’t mnow if theee was anything larger in plastic. Well, that changed recently. So, I had to get this baby because it got floats. :wink:
1/24 De Havilland DHC-2 Beaver kit purchased it off an eBay seller and there is no kit box with box art. Just came in a simple cardboard box. I had an empty 1/32 kit box that I was going to toss but was perfect for this. I make my own box art and glued/taped it on so I know what’s in the box.
Unfortunately, it’s not detailed as Tamiya kits. It does not include interior and clear windows. But, little elbow grease and some spit shine and this baby will be to floating like a butterfly.
Of course, God smiled down on me and I was able to find a guy who designed and prints 3D PW wasp engine these aircrafts used. One big problem solved and rest will come…hopefully :grin:
In the end, when the dust settles it should look something like this…
DSCN0975
