I will always have a soft spot and much respect for Humbrol Enamels.
Even for an inexperienced modeler with a basic starter airbrush like below an a can of Propel, thinned 1 to 1 with house hold lacquer, well stirred Humbrol sprays amazing well.
From 40+ years ago, couple of my very early airbrushing attemps using Humbrol, Badger Basic set & Laquer thinner. Humbrol was the only paint I could get to spray semi decent back in the mid 1970’s.
Yup, I have a small supply of Xtracolor enamels as well. I like those paints almost as much as Humbrol. But they were harder to find at local shops. They had plenty of colors you could not get in other paint lines such as Cold War Warsaw Pact Air Forces, French Air Force, and Bundesluftwaffe colors. Between Humbrol and Xtracolor, you really had a huge line of colors available.
I’m with Robin on preferring to unstick a tin lid over a twist off bottle cap. And once you learn the tricks of stirring the tins, instead of shaking them to properly mix the paint, you get superb results, hand brushed or airbrushed.
Apparently I still haven’t learned that trick, because I have a hell of a time stirring, or shaking them.
My problem with the lids is not getting them off, that IS easy, it’s getting them back on again, tight, so they don’t leak or dry out.
Screw on caps: make sure the threads are clean to avoid issues later
Press on tin lids: make sure the sealing surfaces are clean to avoid issues later
In both cases some effort is needed to maintain the proper function of the system.
I think that cleaning smooth surfaces on a tin lid is easier than keeping the threads clean
but that is just personal preference.
Stirring: Tedious but at the same time it’s almost meditative.
The Zen of Humbrol tins or something …
That’s a great lineup there - I think the red Testors qualifies as true vintage. I remember the big Pactra Flats bottles from the 70’s. The OP - still looking for one older than this -
A basement flood wiped out my old paint containers years ago. But I have an interesting hobby paint story.
I was in my teens when the Wieboldt’s stores went out of business, and there was the Yorktown Illinois store (the space now a Von Maur) when had a semi-abandoned third floor which had some hobby supplies in it. I was tickled to find and buy a can of purple hobby spray paint for nineteen cents, even though I didn’t really get a bargain.
