Hey there hi flyers,
Been a bit since the Salmson got some love and I’ll admit to seeing a daunting task and saying, “I need to get a round to it.” You know one of those circular devices… never mind HA HA.
On with the show!
Not daunting as in difficult, just a lot of it.
And each of these 0.4mm tubes are very time consuming.
Even the fine EZ-line is a nightmare to thread back on itself. Too rubbery sadly yet oddly enough is the reason we all love it. HG’s solution? Use a follicle of hair to pull the line through the 0.2mm inside diameter.
With that worked out I could decide if the upper wing was best left off and rigged or attached.
It was an important decision because there would not be a lot of room to move around. I’m constantly thinking about ways to speed things up and increase the level of quality, thus the decision was made thanks to improving my techniques in rigging.
Everything was all set. Now all that was needed was a NIKE moment.
On it went. Probably one of the more satisficing modeling moments I’ve had over the past year.
Now to make a booster so that the underside of the upper wing was just above eye level and easy to get at. It’s crude yet effective and super cheap
Now I can slip this in my bench vice and angle away to the desired spot.
Here’s an example of the follicle slip loop being executed. Yeah I know… it’s a strand of hair dude.
I’m cheating a bit here by not ending each one, but what difference would it actually make since there will be cable clamps anyway.
I dare you to see the continuous line when the brass rod is up there.
As for size/length of the turn buckles, I went by photos in the manual to gauge them. To me they look great and will look even better once painted.
Just some snipping after the tubes/clamps are placed properly and glued. Things should speed up, now that the muscle memory is at my disposal.
Very special thanks to Sunward Hobbies for sending the kit and paint for review and build. Please visit them online at https://www.sunwardhobbies.ca/ where new items are constantly rolling in.
Thanks Everyone, stay healthy.
