Gentlemen,
thank you very much for looking in, for all your kind comments and for sticking with me here.
So I’m back home and after the usual stuff that needs be done after a while away I found some time for the workbench. First I had to find my way back into the build, what’s to be done next etc…
So some dry fitting with the aft superstructure, see how the Gneisenau conversations to the hangar would have to be placed with the old Shapeways copy of Model Monkey’s parts. (Of course, the good resin ones will be used for the model!) Same 15 cm turret as for dry fitting forward.
While working on several parts, I gave them a first light grey coat, which showed some really bad sinks on the (one piece) funnel. Here already surfacer on.
And wood from the original wooden deck on aft.
Dry fitting distances with a boat between catapult and aft superstructure. I have to scratch build a platform that holds two boats there later on; distance is actually smaller than I assumed during my first fitting trials.
Cutting away the parts of the wooden deck that normally would go around Scharnhorst’s hangar bay to get an even line.
Fitting in the lighter colored wooden deck to cover the whole area.
Once in place, I have to cover the little void between the two parts, but that should not be a bigger problem.
More dry fitting.
And finally for today, brush painting the whole area with mixed artist’s oils to blend in. My goal was not so much to match the color of the main deck but to blend in all parts of this area, will have to see how it looks once dry. For now I think it looks all right.
That’s it for now, I hope to find some more time soon. As always, thank you for looking in and all comments appreciated!
Jan
