Iowa Class Engine Room #3 Model for BB62 Permanent Display
Here’s the “better” steam-driven lube pump. It’s not attached yet to the MRG foundation, just sitting there being photographed.
I still have put on it’s valve handwheel.
I drew the electrical distribution console. It’s ready to go to the slicer and then printing. I detaled all those little handles with the hope that they’ll print. With the recent success making tiny detais, they may just work out. As for the gauge dials… making 1:48 individual gauge face decals using inkjet decal paper has not worked out so well. The decal print is over-coated with some form of laquer to keep the water-soluble ink from running, but with samll decals, it happens anyway and the resolution gets destroyed. I will try. Ryan’s going to get me some good images of them.
Another view as if you were standing next to one of the turbo-generators.
Now for some more sobering stuff. I may be a fabulous, amazing modeler, but I can still screw up. Today I did.
I was so excited about getting the stack drilling of all the frames done, that I drilled the first two large holes in the entirely wrong place. I had drilled 1/16" holes at the ends of each of the slot positions and drilled the same as pilot holes for the big holes down lower. I drilled the two smaller holes on the extended slots at each end and then proceeded to drill the big holes in the tiny hole at the top of the first two slots, completely screwing up all the pieces in the entire stack. This error will not be seen in any but the two end bulkheads, but that’s bad enough.
I have two choices to fix… well actually three. I can fill the two errant holes in the bulkheads and with putty and craftiness, make them invisible. Or I can add one more correctly drilled non-bulkhead frame one bay in from of each end, showing a bit of the 3rd skin in each fire room space. Lastly, I could remake the bulkheads. The problem with #3 is I don’t have enough 0.040" stock left to make them and it’s expensive. I also don’t relish doing all that handwork needed to create them. I’m going to go for the patch first. If it works, I’m done. If it doesn’t I can go to Plan B and still make a respectable model. Choice 3 would be the last resort. Unlike remaking 3D printed parts where the Machine does most of the heavy lifting, doing hand-crafted parts over involves labor and I’m basically lazy.
Amazing work! I no longer have that kind of patience. VBG
I’m sure many of us have been there regarding those remedial options. I can also certainly identify with the laziness syndrome - which in fact you’ve never displayed in this latest masterpiece. I think the lazy thing isn’t quite that, it’s more about “who will ever know or notice?” and to what extent that overrides one’s own philosophy of 100% accuracy at all costs. Whatever, you’ve nothing to lose & everything to gain by trying patching as a first resort.
That sums it up pretty well!
Design work and printing continue. I’m almost at the end of the design phase. I’m kind of in the punch list arena now.
Work also continues on cutting the main framing that supports the whole thing. I went the “patching route” in plugging the errant holes in the fore bulkhead.
I filled them with Tamiya filler and will sand the first coat on Monday. Today’s my wife’s 80 birthday (I married an older women since my 80th is at the end of July) and promised I wouldn’t be in the shop today. The rest of the filler is patching the deepest surface scratches that resulted from over-aggressive sanding of plastic cement remnants that I used to hold the stack of frames together for cutting and drilling. I was amazed at just how difficult it was to slice them apart. I’m going to try a different method to do the same on all the cross longitudinal frames. I’m also not going to attempt to cut the slots by sawing. They just wavered too much. I’m having to recut them all with a #11 blade anyway, might as well cut them that way from the start. And I’m using a square to keep them nice and vertical.
The evaporators are printed and trimmed waiting, along with a ton more stuff, for some paint. I printed them hollowed out to reduce the resin quantity. I also included plugs left over from the hole-drilling task in the slicer. The plugs are a press-fit back in the holes and needing no glue. A quick sanding and the holes disappear. I use a large syringe to wash the resin out of the interiors with IPA.
Front view. I chose to simplify the plumbing on these, since I couldn’t make any sense of it. Ryan thinks they look great.
The entry catwalk is hung from the ceiling! It is not fastened to the main reduction gear that lies below. To replicate this, I’m creating a faux ceiling to support it. It will also support the entry hatch which is a feature I didn’t want to leave out (not yet designed). All of these frames are sliced and ready to print. None of the framing is a 1:1 replication and asserts a lot of “modele’s license”. The ceiling structure is more varied than how I’m depicting it, but viewers will understand. I taking advantage of the accurate main support pole in holding up the ceiling structure.
I also lined out the flooring supports for the main control board and the main air ejectors. Both of these are at the fore end of the engine room. Had to fuss a lot to get the support poles to clear all the apparatus below. Again, the flooring is not truly accurate with much of the support would hung on the cutaway fore bulkhed. This is the Air Ejector flooring bracing. Also note the added support on the flooring system running into the picture that holding up the catwalks next to the turbogenerators and electrical decking.
And here’s the port side floor system.
Lastly, here is the flooring system and electrical console on the slicer and ready for print. This file and the other floor bracing file has been transmitted to the printer and will be print next week. The only reason the main control board’s not ready for print is lack of information. I’m waiting on Ryan to send more pictures of it. It such an important feature that I want to make it right. I’m hoping that all the switches and levers on the electrical console print correctly.
I’ve ordered and received most of the electrical materials for the lighting. I’m using surface mount LEDs again, but in this installation, I’ve gone to cool white to replicate the florescent lighting used in the 1:1 space. I was able to get 200 LED chips for $6.35 plus KY Sales tax from Amazon. That’s $.03 a piece. Ridiculous! And they are very, very bright. I redesigned the electrical console with space for the LEDs and their wiring. Lighting is going to fun and challenging. It’s also going to add life to all the underneath details.
Great detailing with the printing, those grates and ladders look super. Coming along really nicely.
Missed yesterday’s post so today will be a twofer.
First up… thought it would interesting to see the vast number of parts already created for this project. We’re at the 95% level. I finished printing the smaller flooring frames and they’re waiting for trimming and sanding. I’ve also uploaded the file to print the remaining large floor frames. I’ve almsot finished drawing the various electrical cabinets, and Ryan has promised that he’ll take pictures of the main gauge board, which is the last piece to be finished. In those plastic boxes are all the floor gratings ladders and diamond plate pieces. All of this and no instructions! I’ve received all the electrical materials and am going to do some experimentation of soldering on copper foil attached to resin. Resin doesn’t melt per ce, but it can burn. If I can it would simplify attaching the surface mount LEDs. The large curvy pipe at the top is the new main steam pipe that has clearance built in to clear that large central pole (resembles a rocket in the foreground).
I printed the tiny hand wheels for the auxiliary air ejectors. I chose to mount them with 0.015" phos-bronze wire. I had to drill the parts with a 0.016" carbide bit. I got through almost all of them before breaking one. I attmpted to attach the even tinier smaller valve wheel using wire, but it proved ridiculous. I ended up putting them on with CA.
First image shows the valve hand wheel attached to the wire. Note the fine-tipped tweezers for scale.
And the finished parts: Pins are also installed in the pipe ends to faciliate gettimg them attached to the ma
I took some time off to rebuild additional lighting on my workbench. I had two of these puck lights left over from an under-cabinet project and used them for a couple of years. The voltage adjuster died rendering them dead. Another under-cabinet job gave me two more surplus LEDs pucks that I added to the one remaining. They’re 12vdc units and require no current management circuits. They just need a 12vdc power sorce. I needed another LED power supply for the engine room project so I bought two. I wired them up in parallel and added a toggle switch to activate them. Lots of needed light.
The circuitry isn’t pretty, but it’s solid and safe. That circuit strip needs some craft work to parallel the contacts, but jumpering them. The strips came from when I built my first railroad at our house in Düsseldorf, which explains why their “Euro-style”. I used them all over my model railroad and I’m finally running out them. When I decided to build my railroad in our German house, the head of the technical training department at Henkel provided me with an enormous amount of electrical hardware to make it all happen. It was when I learned about crimped ferrules on the ends of wires that are used along with these knds of terminals.
I printed the electrical control panel in the same run with the miscellaneous floor frames. The frames came out perfectly, but the panel was a failure.
The failure was not the printer’s fault. It was the draftsman… me. The drawing was flawed. There was a layer underneath the slant panels. The printer/slicer was confused by this inner layer and tried printing both. You can see this inner panel in the centeral area where another slant panel was supposed to go. I went back and fixed all the drawing errors. I printed it again solo, and the results are perfect. It’s draining on the printer and I’ll finish it up tomorrow. While it’s hard to see with all that excess resin covering it, the control knobs and switches did resolve.
Back to the main floor framing. Oh boy! I wish I could have had it all laser cut. It’s been well over a week and I’m still cutting away. I keep refining the process, but it’s a lot of heavy duty hand work.
After scribing and snapping all the long cuts, I used the Northwest Short Line Duplicutter 2 to gang scribe the cross-cut length.
To make the stack of the fore and aft beams, I used Scotch Double-sided “permanent” tape. It held the stack well enought and came off with no residue or sanding. Using plastic cement was more trouble than it worked.
I used a prick punch to locate all the holes and then pilot drilled the with 1/16". it was a bit too small for the big holes, but was perfect for the tops of the cross-lap cuts.
The big drill was okay… just okay. It wandered on a couple of holes meaning the some of the slots are not parallel to the part edges. Annoying? Yes! Show stopper? No! It’s all at the very bottom of the model and recessed from view. Won’t be seen much except by me. These holes drilled much better than the ones I did on the abaft ship frames. Part of that was due to holding the stack more firmly with a drill press clamp in additionl to my fingers.
I started cutting the scrap between the holes with the #11. I didn’t like how it performed. I switched to a single-edged razor to start the cuts. Worked better, but still not so hot. Finally I used my 90º corner chisel. This worked well. I don’t have any straight wood chisels. A 1/4" inch chisel would have been perfect.
I started doing trial fits with satisfactory results. There is another, 2nd skin mid-point in the framing. I’m going to add this only in the outer spaces since the inner ones would be invisible. The triple bottom was only used under the hull areas included in the armored citidel.
You are now all up to date.
I am in awe at your work and modeling skills! Wow.
Thanks… It’s a whole lotta trial and error going on.
The electrical control panel exceeded my expectations. The elevated switches on the panel resolved with the levers in the various positions. Now all I have to do is paint the darn thing which could be a lot of fun (or not). The problems were entirely with the drawing. Fix the drawing… fix the part. As close as I could tell from the photographs, the controls are as they are on the real thing, even to their disposition.
​Work continues slowly on the under-framing. I keep developing better techniques. By the time I finish all of them I’ll have it all figured out. I did find a chisel narrow enough to chip out the material between the circles. Even with that, I had to refine how I was chipping it out. Instead of making three separate hacks at it, I found that if I slid the blade down a pre-scribed line (from a #11 blade and straight edge), the removed part had cleaner edges and leaving me with much less cleanup of the openings.
​While assembling the array for trial I realized an error was cropping up. The abaft main frames taper from the middle to the edges as the real floor does to let any water to flow towards the bilge wells at the outer corners and be pumped overboard. I, foolishly, wanted to faithfully represent this slant and built it into all of the cross-frames. That meant that all the fore and aft frames, depending on their location, would have differing heights. I built this into the patterns. But… I chose to cut them all from one template meaning they were all the same height. My mom used to say that "G_d protects fools, drunks and little children. In this case he protected the fool. Luckily, the template I chose was the tall middle one. At least I could remove the excess stock on the ones that are shorter out at the edge. It could have happened in reverse and I would have all the middle floors not reaching the tops of the main frames. As i progressed today, I took individual caliper readings and used the digital caliper as a height gauge scribing the correct height so I could shave off the excess.
​Putting the frames together was a little like herding cats, so I decided to tack glue some selected joints to stabilize it. One of them was on the “front” bulkhead. Later, as I added more fore and aft frames and then more main frames I found that I had hung the rear bulkhead where the front should go. Again, lucky that I only had one flimsy glue joint to break to make the exchange. I’m glad I’m doing all these trial fits.
Here it is with correct rear frame at the rear. It’s going to be a challenge to ensure everything is square. Also, liquid cement is not sufficient to hold the cross laps due to their slop. I will go back and use tube cemnet after everything is tacked in place. The flooring itsellf will be 0.030" styrene sheeting and that will made the whole thing very strong.
We’re heading out of town on Thursday so reports will have to wait until next week.
Hey Myles, just wondering, what’s the thinnest wall section you’re able to achieve when printing parts?
Fabulous progress by the way! :slight_smile:
This printer, unlike my previous two, can print sections that are 0.010". Just becuase it can, doesn’t mean it’s a good idea. The resin in those thickness is weak and will probably fail during handling. That said, when the section is well supported and not hanging out there, the printer amazes me constantly.
We had friends from our old neighborhood in Philly area over for a long weekend, so I got back into the shop today. First of all, the framing and column print from last week, while successful print-wise, won’t work model-wise. The I-beam columns I drew and printed, while delicate and scale-like, was too frail to exist in the real world. I changed them to H-beams and doubled their cross-section. That print finished a short while ago and I will clean them up tomorrow. Pictures to come tomorrow.
I spent the rest of the work session cutting out the first skin (ship’s bottom) and showly gluing the lattice to it. While at it, I am also adding the 2nd skin on the outsde exposed spaces. There are slight variations in spacing so each 2nd skin piece had to hand measured, cut and fit for a nice glue joint. I’m using both Tamiya thin cement and good old Testor’s tube cement due to its gap filling abilities.
I’m employing angle blocks of various sizes to weigh down the lattice and to give a nice square corner while glung. I have to be careful to shim the outside since only part of the block is sitting on the bottom skin and it led to a tipped block. The shim kept the blocks level so the 2nd skin is also level. I haven’t glued any of the sides or central lattice yet. I wanted to get the fore and aft bulkheads well attached before gluing the center which will not be seen. I think I’ve found a spot where I could cut open the floor a bit to show the triple bottom which is so characteristic of a warship like this one.
I started the glueup with the rear bulkhead since it is only sitting on a little lip. I wanted it glued tight. I also cut a 3/8" strip to sit on top of the little lip that remains. This extra piece will give the 3D-printed external stiffening frames a bittle bottom on which to sit.
With the back bulkhead in place, I started working on the front. I’m gluing the bulkhead and the 2nd skin pieces together as I move along. I have a few pieces on the extremis left to finish this step. The upper bulkhead and framing will be white, while all the underneath skins and frames will be red-lead or something akin. The little “tables” are 3D-print fixtures to set the height and level of the 2nd skin. By doing it this way, i didn’t need to glue any corner or edge supports to hold the 2nd skins in alignment. Plastic cement does not affect UV resin. These too needed their outer legs to sit on shims to hold them level.
Only 3 more 2nd skins need to be added to the fore bulkhead. I will also add 2nd skin pieces to all the open sides and then just a few in the area that’s going to be cut away for vieweing.
The re-designed and re-printed minor flooring frames came out well and the enlarged H-Beam columns now have the structural integrity to support the platforms as I needed. I also added sockets printed with the frames to capture the H-Beams. I made the socket openings slightly larger in all directions so the columns just drop in without forcing. I will use CA to hold them, but use epoxy to glue the columns to the floor system.
The Main Gauge Board floor system attaches to the larger and more robust frame holding up the evaporators. I made the mating beams so they could nestle into the larger frame. I was rewarded that it fit as I drew it. This frame has four columns although I probably didn’t need them since the one end is attached to the larger frame.
For the evaporator floor frame and drew some brackets to provide a stronger mount to the Turbo-gen frames and the other free end supported by two H-beam columns.
Looking underneath you can see the brackets, but they’re suffering from a depth-0f-field problem with my iPhone’s camera. I have an iPhone 12 Pro. I’m thinking about upgrading and wonder if the iPhone 16 Pro’s camera has better custom focus control. I take many closeups among the thousands of images I’ve made documenting my model building pursuits.
Meanwhile, I’m putting in more of the 2nd skin floor filler pieces. Only one more side to go. I may have to paint the insides of this before glueing down the hold floor since you can peer through all the holes and see the insides. You won’t be able to see whether there’s a 2nd skin in there, but you might be able to see all that white styrene. That said, the entire framing interior will be in the dark. So maybe, I won’t have to paint it. A couple of the fore & aft frames are sitting a little low. I will shim them before gluing on the floor panels. I want the panels and smooth as possibel since so much has to be fastened to it. Notice the hole cuts in the face of the fore bulkhead to provide passage for the condensate water ram intake. There’s a couple of other holes needed in the hold floor for more intakes and discharge ports. I’m not opening up the bottom as the model sits on it and it’s not visible.
That narrow fire room floor is necessary for two reasons: a base for the wall stiffeners that are on the boiler room side, and for passage of that ram intake. Everything at hold floor level and below is oxide red, bulheads above that are white. It’s really getting excited about thinking about starting construction. Still have two more details I need from Ryan, but I can proceed without them. They are not in the critical path… yet.
Interesting day! I got the 2nesd skin inserts done without issue and turned my attention to the entire floor structure. I was thinking about taking it outside to apply the red primer, but I decided instead to start fitting some of the critical items to double check fits before getting ahead of my skis. Boy! Am I glad I did. The port side prop shaft, bearing mount and seals aligned perfectly with the floor (temporary piece of 0.030" stock) and the holes in the fore and aft bulkheds. I was also rewarded with the output shaft lining up perfectly when the high pressure turbine frame, on the other end, aligned. But the starboard side prop shaft didn’t align with the seal hole in the aft bulkhead. This would not do.
It required some serious surgery and some grafting. I traced the correct location on the bad part and then cut it off by scribing and snapping.
I then used it to trace a replacement. I didn’t like the lack of stiffness anyway and needed a flange to properly glue the graft in place, so I made the first piece long enough to have a lip that extended down to hold floor level. I cleaned this up and tried it out for fit. It worked well.
I then used it to trace another piece, but this was had the traced cut line from the severed part so it would closely match the glue line and mitigate excessive filling. After gluing the two together, I finished sanded them as a single laminate. I glued this in place with tube cement and clamped it until set.
Tomorrow I will finish the joint with filler as needed and make it invisible. With the double thickness, there is now some extra material behind that will have to be accounted for when fitting in the hold floors.
While doing this it became clear that ALL the stiffeners needed to be secured since there would be CA and epoxy that would make a mess of any finished paint surfaces. I started with the fore bulkhead by adding the stiffener for the HP turbine frame. I used thick CA and then added epoxy where it needed more strength on the bottom horizontal piece that simulates the fire room floors.
I also added an I-beam to stiffen the wall where the main steam line passes through the bulkhead.
Here are the two stiffeners in place.
A top view shows the 3º angle that the main propulsion system sits so it’s aligned with the #2 propeller. It’s neat to see the parts in place and how they replicate what I’ve drawn.
Boy, am I glad I put my foot on the brakes and didn’t spray any paint. I’ll added the stiffeners on the aft bulheads, and then I can spray the base red primer. I will then glue on the hold floor and paint it too. Once the base is prepared, assembly can being in earnest. The weather’s warming up so outside paint days will be more frequent.
What a marvelous job you are doing! Amazing.
Thank you! It’s a battle!
I spent much of my build time creating a set of numbers on stalks that are going to call out the various components folks are viewing. It will tie into the key that will be attached to the inside of the rear acrylic case. They are not large and will be unobtrusive. This little drawing job should not have taken as long as it did. SketchUp kept crashing when doing the Move/Copy function to rotate and copy each number to the other 3 faces of the cubes. It seemed to have crasked on every other cube. Some crashes were the “Beach Ball of Death”, something that happens on Apple computers when the program is hanging. Other times, SketchUp just shut down. Each time, I had to reload, catch the backupped file and get back to work. Wasted time!
I then got back downstains and worked on the other bulkhead. After epoxying the stiffeners in place and cured… hard!, I noticed a error I made. On the fore bulkhead I correctly had the stiffeners on the small chunk of the #2 fire room’s hold floor. But on the aft bulkhead, I made a mistake way back in the initial design stage of the flooring system. I incorrectly used the tabs from the cross-lap joints. These are not the floor height, but represent the 2nd skin height. I had mounted that small strip thinking that was the floor level.
If the epoxy wasn’t so darn efficient I could have removed the now-secure stiffeners and revised the flooring system, but alas, the epoxy worked way too well and cured way too quickly.
I’m going to add the hold floor strip and added verticals in preparation for this. It will be different than the other bulkhead and it will be interesting to find out how many viewers notice the diffence. It will appear that the stiffeners penetrate the hold floor to the 2nd skin. For all I know, this may be just how they’re tied into the ship’s structure. Tomorrow I will add the floor strip on top of the new parts simulating the hold floor. The clue that I made a mistake was the stiffeners not going up to the top of the bulkhead cutaway wall.
I’m also going to glue in the propeller shaft seals into the bulkheads since they’re going to need epoxy as well and it’s much better to do it before painting. Other stuff also connects to these walls, but I’m not ready to add them. These parts include all three of the air ejectors and the high pressure turbine’s mounting bracket. If I have to, I’ll remove paint in these areas or mask them for better epoxy adhesion.
For some reason, I was considering the aft bulkhead as something different than the forward one, whereas they should have been treated alike. They both should have had full height extensions to support the little bit of fire room hold floors that would have supported the stiffeners. By just having the cross-lap extensions on the aft, threw me a curve that didn’t cross the plate until too late.
Friday’s work consisted of finding that the prop shaft coming from the main reduction gear was also misaligned with the hole in the rear bulkhead and required the same surgical procedure that I used for the through prop shaft #1. Again, I doubled its thickness to provide a gluing lip for strength. Even though the cut was a bit irregular, I traced it on the new piecce so there’s not too much filling to be done.
After clamping and gluing, I smeared some Tamiya Fine Filler on and will sand this joint and the other one tomorrow.
I printed the callout numbers 1,5X larger than my first attempt and these should do nicely. I’ve kept the smaller ones as they may prove handy for smaller equipement or hard to reach places. I’ve identified 26 pieces of interest in the model.
I finished designing the lube oil purifier. It’s a centrifuge that spins out any particulates that are entrained in the oil. I only had one, not-so-hot photo on which to base the model. On the main drawings I was able to pick out the overall footprint and height so I know it’s not grotesquely out of proportion. It sits under the evaporators and will be hard to pick out therefore, I will be counting on the lighting installed to give it some life. I have absolutely no idea where those pipes actually go.
​The last thing I did today was add some leveling shims on the lattice frame and then measure, cut and fit the 0.030" syrene sheet flooring. There are two halves since they both slope towards the outside from the ship’s center line so wall will run off to the bilge scuppers at the extreme corners. This isn’t glued it and won’t be until the painting of the of the lattice is completed.
Weather might be okay a couple of days this week to do this painting outdoors. Two more parts to finalize and draw and we’re onto paint and assembly. I’m at the stage where the assembly order becomes critical. I already saw how difficult it can be when attempting to get the main gear box and its prop shaft through the bearing. I may have to glue the bearing in AFTER the gear box is installed. Lots of work still to do. I’m now a the point where I will actually be building a model.
Got two things accomplished today: painted the red primer on the underfloor and printed the Lube Oil Purifier.
I masked the parts that were to remain white. I didn’t want to have to paint white over red primer. I then took it outside, donned my vapor mask and safety googles and started spraying from the can, Rust-oleum red primer and got half way through. The nozzle clogged up. Can was half full. I called the ACE hardware nearby and asked if they sold Rust-oluem spray and they did. I drove over there in rush hour traffic and they didn’t have the color. But the salesperson asked if I had any other cans of paint and if so, use a nozzle from one of those. I got home, got another nozzle, and it worked fine. I finished the job.
It’s amazing how much sloppy workmanship that paint covers…
I also glued the support legs into the two deck frames with thick CA and then had to level the Main Air Ejector’s frame with the TGs frame to which it’s attached. I glued the shims on with CA. There may need to be more shims to make those upper surfaces level while sitting on the sloping hold deck halves.
Lastly, here’s one of the two Lube Purifiers that I printed (always print more) and this one was perfect. The other had a small pipe that failed to print well.
Till tomorrow…
Incredible work :+1:
Thank you!
Ryan sent me a load of pictures yesterday including the main gauge board. He also sent images of the ambiguous electrical cabinet that I needed to finalize the upper mezzanine and images of cabinets on the lower mezzanine. The latter are very hard for me to interpret since it doesn’t show the entire array or how the images realted to one another. Lastly, he sent pics of the lube oil storage tank and the strainer that sits below it. Again, the strainer pipiing is covered with insulation and is difficult to understand. He missed the lube oil settling tank of which he wasn’t too familiar. It’s on the same level as the main gauge board and sits against the side wall. I’m not sure about including either tank. The storage tank can be supported by the aft bulkhead, but may block views. Since I’m not including any side walls, the settling tank will have nothing to support it. It would also block the view of the gauge board which is much more important.
The three pics of the gauge board were shot standing facing the middle and then simply turning to face right and left for the other views. This created a very distorted series that needed to be edited before I could use it as a drawing guide. I downloaded the three images into Corel PhotoPaint and redid the perspective on all of them so they could be merged into a single, reasonably-sized image. Then I was able to draw the panel.
The raw images:
My edited composite:
A rendering of the final drawing:
And the panel set up on the slicer for printing. It’s being printed as I write this. The main gauge board has the RPM prop shaft counters for the other three engine rooms so the chief engineer can keep an eye on them. There are also other gauges and controls that are not present on the other three panels.
I would love to have decals for the gauge faces, but can produce them in my shop. Inkjet decals, when they are very small, tend to have the ink run even when they are properly overcoated with sealent. Inkjet ink is water soluble. Professional decals are either silk screened or printed on other machines that can print white. I’m sure it I wanted to pay for them, I could get them custom made, but this model gets donated and I manage my costs closely.
I still have to finalize the Lube Oil Tank situation, the electrical cabinetry, and the piping configuration to the large lube oil cooler. The cooler resides on the hold floor below the line of the lower diamond plate personnel flooring, so it’s piping is mostly concealed. It needs coolant inlet and outlet, and lube inlet and outlet, but there’s two more outlets unaccounted for. It may be that each pump has piping to the cooler, but I don’t know. I haven’t found any information about this. Lastly, I have to created the telephone booth that sits beside the main board. With that done, all printing will be finished.
I fitted the floors and then applied the equipment again to test fits. First the lattice painted. Stil have to mask it and paint the white styrene gloss white.
Becasue you can look through all the holes is why I had to paint the whole deal.
The floor fitting.
Notice those angles of all the drive lines. The props are not square to the ship’s centerline. Probably helps pushing the ship in a straight line like alignment settings on a car’s front end do.
The main gauge board printed… sort of. I had made the classic Drawing for 3D Printing error. I had parts that weren’t actually contacting the surface on which they should have been. I wrote about this error in my book “21st Century Modeling…” so I should have known better. All the other details printed perfectly, but the part is scrap. I corrected the drawing and will reprint on Monday.
Notice that all the small gauges are either missing or deformed.
The reason: Almost all the small gauges were sitting proud of the surface by a very small amount only seen when you orbit and look directly at it from the side and zoom in.
It didn’t take long to correct the drawing and re-slice it. When designing for printing (like anything else) the details will kill you. It’s very hard sometimes to see if surfaces are truly in contact. That said, the details that did print are impressive.
Before printing the new gauge board I had to empty all the resin and remove the little gauge circles that were not attached to the panel. When the printer attempts to print an unsupported aspect, it will start to form on the teflon vat bottom film and then at the next cycle, when the machine attempts to separate the forming part from the film, it leaves the unsupported blob on the film. It will continue to acrete more resin since the LCD is still exposing that spot. This will continue until the blob is thick enough block the UV light and it just sits there. If it gets very high, it can apply significant pressure on the LCD screne when the lead screw is bringing the build plate down to print position, and possibly crack the screen. Never, ever start a new print after a failure without first emptying the vat, inspecting for anythign stuck to the film and removing it.
When I re-ran the corrected-drawing version of the main gauge panel, I was greeted with a perfectly beautifully printed object. The little bumps you see on some of the gauge edges are very tiny supports that the slicer automatically placed there to catch a face that would start printing before the panel behind it. If unsupported, there would be risk that the gauge face would not form properly.
While this print was running I started working more intensely on fitting the big equipement. The weather wasn’t conducive to painting the floor panels, and I’m glad I didn’t since I had to cut the opening for the main condensers big piping. The was a classic trial and error afair and took most of the afternoon. It was made more difficult because the parts were not fastened together and it resembled herding cats. I finally resorted to taping it together. Because the intake and discharge coolant pipes exit on opposing angles. I had to keep enlarging and changing the opennings’ size and contours to get it to work.
In addition to the holes in the floors I also had to open up the lattice below to accept the piping. After chopping and hacking as shown in the picture, I ended up cutting out that wall entirely. i did the same thing to accept the intake for the steam condensate pump.
In my drawing I noticed that the condenser was sitting about 1/8" too low causing the low pressure turbine’s output shaft to misalign with the main reduction gear LP input shaft. I knew I had to shim it up and did that today so the piping would be sitting at the correct height. I also am thinking about tapering the ship to level the LP mount to account for the deck slope angle.
The extra large holes are just aching to have a trim plate to close them off. In the 1:1 ship there is an elaborate series of plates and seals that surround the condensate piping as it passes through the triple bottom. Afteral it has to be watertight. On the model you wouldn’t see it, plus building it would be darn near impossible. I also started preparing the main reduction gear housing. There was an unseemly gap on the port starboard joint edge caused by a stuborn warp. In preparation I used some J-B Weld epoxy putting, put some Pess-n-Seal on the flat side and put the putting in a string on the film. I clamped the upper, warped half in place in a wood workers vice and squeezed out the excess until it was fully sealed. I’ll finish sand it tomorrow and drill the holes for the small screws that I’m using to hold it together. I don’t want to glue the beast since I want to be able to assemble it on the model and screws are the correct choice.
