KET - T Recovery Vehicle Build Blog
A simple detailing hint that you might want to add: – The framing of the “hood” structure.
It was a nice one evening’s project spent with a couple of packs of Evergreen plastic shapes and the result ends up as being much more realistic than that which is included in the PE fret.
Trying now to find the credit for the guy that did this fantastic CAD model of the MA3.
OK – here it is.
Shown here as my work in progress.
(These roof beams are made out of 1"x3" welded square tubing and not thin wire as the PE fret would seem to indicate.)
Edit ~ Additional Photos Added
White glue (optionally thinned with water) is my thickener of choice for PE parts.
Peter
Whatever works to get the job done.
I would think you would get better adhesion by using paint but I have never tried white glue for this so I can’t say.
Here is the link to the E63 Paper Models free webpage:
E36 Download Page:
That is a very nice site, those pictures look like ‘normal’ models, very impressive to realise it is paper.
Agreed ~ I used these paper model parts layouts and general information back in the day to help properly detail the old, Old, OLD Dragon model offerings of the MA3 that where out there back then,* this was well before the all new tooling became available from Trumpter. With the old Dragon offering the driveline was almost totally incorrect and horribly detailed.
*This was OK when all that incorrect detail was well hidden under the Scud Missile TEL bodywork but when they offered the 537 as a semi tractor where the driveline was exposed to view I just couldn’t stand that any more!
Here are my rebuilds to the early Trumpeter transmission and transfer case built many moons ago, based primarily on the information gleaned from the E63 reference:
Another detail left out of the early Trumpeter model of the MA3: These two large air tanks mounted one on each side of the frame, between the third and fourth axles.
Did Dragon release a kit of the MAZ-537 in 1/35?
I was under the impression that they only released the MAZ-543 …
Dragon, years ago, offered the MA3 543 chassis as the Scud missile carrier TEL with the split 4 passenger cab.
I’m sorry Robin, you are correct - it was Trumpeter and NOT Dragon that first started releasing the 537 as the semi-tractor and Airport Tug - MY BAD - TOTALLY!
Trumpeter issued three versions of the 537 chassis (very similar mechanically to the 543) with the solid cab as seen in this thread.
  • MA3 537 semi-tractor with optional winch (early).
  • MA3 537 semi-tractor* (late, with slightly revised body work)
  • MA3 53L airport tug* (with ballast load body mounted on the rear.)
    *(Also with optional winch.)
92b613d6a04af4d1810e538f5ceddd656549b3c9_2_690x416
Here is my much revised Trumpeter early 537 with winch. The winch is removable to view the now highly detailed driveline. I always thought the early version with the exposed fuel tanks was more visually interesting - now I am working on a full engine for this monster!
Trumpeter is making full use of the new tooling on their model by offering many varied model versions of this vehicle: S-200 & S-300 missile launchers, the AA60 Airport Firetruck (based on the 543), the basic load carrier/truck (again the 543), KET-T, “Carrier Killer” missile launcher, “Flap-Lid” radar unit, and I am sure several other variants I am not aware of.
One thing I do know however, the Russians have made great usage of this 8x8 chassis and there are many more variants that Trumpeter could make use of in the future if they so choose.
220px-MAZ-543_airport_tender
MA3 airport “Fire Tender” now offered by Trumpeter - even this vehicle was built in 3 versions so there is LOTS to model!
I had been working on my own Fire Tender, but then the Trumpeter version came along. I was rather liking the prospect of building something in other than Olive Drab or Russian Green colors.
I am sorry and I apologise to SSGToms - I seem to have been monopolizing the conversation here of late - that was not my intent.
It is just that I have so much photo research on the MA3 that I would like to share. Unfortunately the majority of my info is on the general vehicle and driveline - not specific to the KET-T.
Would love to see this recovery vehicle in action!
Nice scratch building.
Ralph
Great build. I like recovery vehicles.
Ralph
Ditto that mech!
MA3
After spending several cups of coffee on Google, I have come up empty on in-action photos of the KET-T, believe it or not. Here’s the closest I found:
That’s actually a pretty good illustration of it’s recovery setup. Here’s a display of it’s towing capability:
And good photos of the KET-T driving by. I guess they are easy to spot when they come through your town!
This truck is truly a monster, but how thick is the sheet metal on that cab? Only as thick as it needs to be! Obviously, you can dent it with an elbow! The rest of this truck is all business, though.
The KET-T is a heavy recovery vehicle. It is based on a MAZ-537 8x8 heavy high mobility vehicle. This vehicle is fitted with special recovery equipment. It entered service with the Soviet Army in the 1960s. Despite its age the KET-T is still in service with Russia and possibly some other countries.
The main role of the KET-T is to recover varuious damaged, overturned, swamped, or stuck 8x8 military vehicles. The KET-T also provides maintenance service and tows vehicles to maintenance units.
This heavy recovery vehicle is fitted with a 15 t capacity recovery winch with 100 m of cable. With the help of pulley blocks traction force is increased to 46 t. Maximum traction force is up to 80 t. Recovery winch is mounted on a special frame. This frame is also used to lift disabled vehicles onto a special towing bar. Also there are two jacks that stabilize the vehicle during recovery operations. Recovery frame can be also used to lift various loads with a maximum weight of 1.5 t. This vehicle also has a welding outfit for welding and cutting works.
Vehicle is equipped with towing bar and towing cables. Disabled and uncontrolled vehicles are towed semi-lifted. Vehicles are towed to the nearest shelters, assembly points of repair depots.
The KET-T is operated by a crew of three, including commander, driver and handler.
Vehicle is powered by a D12A-525 38.9-liter diesel engine, developing 525 hp. At its time it was a standard tank engine. However this engine has short service life. Vehicle has a full-time all-wheel drive. There is a power assisted steering of front four wheels. Standard equipment includes an engine pre-heater, to assist starting in cold climate, and powerful cab heaters. A central tyre inflation system is fitted, to provide better traction over sand and soft ground.
There is also an MTP-A4 repair and recovery vehicle, based on the MAZ-537 chassis.
A newer version of the KET-T was built on KZKT-74281-012 8x8 heavy high mobility chassis. Sometimes it is referred as a KET-TM. It is unknown if this modern version of the vehicle has reached production.
I am mating the cab and fenders together and installing the glass (uh-oh!) now. After that it will be masking and final green airbrushing. More progress photos on the KET-T this afternoon.
I have now built 3 of these monsters in 1/35th and I am looking at starting a fourth. If it were me I would HAVE to consider posing this model in a recovery operation with those feet down on the ground and that big A-frame up in the air and the vehicle hard at work!
Would not show a second vehicle but just the cables somehow going off into the distance like in some of the photos seen here. (Perhaps into the water to recover an old WWII tank?)
Nice detailed breakdown and explanation of the KET T Matt. Perhaps the lack of photo evidence of them in action goes back to something @ayovtshev alluded to on his radio truck build. The old Warsaw pact countries didn’t particularly like or encourage photos to be taken of service vehicles or service life in general unless it was in a pro and good PR way, and we once got briefed by Int Corps that they really didn’t like photos of broken down or damaged equipment being taken or published which could threaten how they portrayed themselves to their population as the all conquering force with fantastic kit… Probably still like that now to certain extent in Mr Putin’s autocracy…
I’ve got the cab together and everything now is covered in AK Real Colors Modern Russian Green. I have to touch up the flat black beneath the cab. I believe some major assembly is next.
Looking good Matt and on track for a lovely big 8 wheeler… Or rather I should say, another lovely big 8 wheeler :grin:
