Hi Everyone,
The Type 21 Zero was the true production model of the original design with the inclusion of folding wing-tips for carrier operations. As such, in my opinion the best variant per the original design IJN requirements. Range for its time was unheard of, speed and firepower, made it the most advanced fighter in the Asia/Pacific theater when introduced. These pluses of range, speed and firepower would be offset by the design sacrificing any defensive weight (armor, sealing fuel tanks, etc.), while most aircraft of the time had these deficiencies, the IJN overcame them with having highly trained pilots, something that the attrition of war would nullify in a relatively short period of time.
As part of my personal tribute to the 80th anniversary of the Battle of the Coral Sea, I focused on the primary combat aircraft of the battle, all from one ship on each side. For the US it was the USS
Lexington, and the IJN it was the Zuikaku. I decided to model Tetsuzo Iwamoto’s mount from the battle, which would be the same plane that he flew during the Pearl Harbor attack. This would mean a Zero roughly 5 - 6 months old, where per reports the nice green/grey color began to oxidize and turn to more of a grey. For this build I tried to replicate this weathering.
As with the Type 52 build the first order of bussiness was to lay down the insigna and marking colors white and red.
Type 21 in the forefront:
Next, I masked off the hinomaru’s and stripe areas.
Then I gave the bird a base coat of gloss black. In the past I’ve used a dark brown base coat, but feeling a bit adventurous, I chose black to see if it would make obvious differences in weathering effects.
I then proceeded to play with white and IJN grey mottling, and gave it a light overcoat of JN grey, Mr Color 15. There is a slight difference between Mr. Color and Tamiya JN grey, with the Tamiya having a slight greenish hue to my eyes, hence the choice of Mr. Color. After removing the masks, I re-masked to clean up the stripes on the fuselage to assure a nice demarcation which would include the “window” for the planes data/specs markings.
While this looked fair, based on photos from the battle of Celyon I felt that there should be a bit more green/grey added. Using Tamiya XF-76 I proceeded to highlight the panel lines, and then blended everything with a very dilute JN grey.
I cobbled together the tail numbers, data information, “no step” and crew chief data decals from the dungeon and was pleased with the outcome. This was followed with an oil wash of burnt umber and some slight streaks.
All that was needed was to add the landing gear complete with brake lines, arrestor hook, and aerial using EZ-Line.
I then added the prop and called her done!
I was very pleased with the outcome, it could be my best rendition of a Zero yet. The Hasegawa kit while some say long in tooth really does result in a wonderful representation of the Imperial Navy’s premier fighter during the early stages of the Pacific war. I highly recommend it to all modelers. I hope you enjoyed, and it’s onto some more birds from the Land of the Rising Sun!
