Figures are looking good.
Thanks matey… Once the flesh goes on and hair colour along with the shoulder board and cap piping etc, that should make them look a lot better
How are you going to paint the flesh?
That camo uniform looks quite good!
That camouflage looks great! 44 dot?
Not sure about 44 but definitely 2022 off the cuff SWAG … Glad you like it though
Looks like 44 dot. From part of the Stanton repro German winter reversible to white parka collection: spring/fall 44 dot and splinter A.
All joking aside, I was just trying to follow the lower pattern on the box painting instructions…
The one above it looks like a 44… Nice collection though
Did you use any particular method, follow any particular painting guide or just wing it based on the boxart?
Looking good either way.
Total wing it… Glad you like it though. I did the initial cam, then left it for a day or 2 and went back and did pin point detailing using xf 27 to gap fill.
Great stuff - looks oak leafy enough to me. I think I’ll try the wing it method instead of trying to follow painting guides on YouTube in the hope it’ll come out as good as yours.
Well spotted
I had a quick look at the guide then really just winged it. I started with a base coat of Tamiya xf52, then patched in areas with xf27. Let that dry and mixed Tamiya xf 5 green 50%, xf 3 yellow 30% and xf4 yellow green and xf2 white about 10 % each and put in patches and small spots of that over the previous 2 then after all that had dried, went back and did the pin prick dots of xf27 to gap fill.
Nice job n the uniform Johnny
Seriously didn’t realise how much time had gone by…
So, let’s get the Tiger done.
The wagon is pretty much there. Some detailing to finish and I need to find/make a Notek convoy light, the Commander will get the Archer collar tabs and cuff band ( and hand and cap lol) and the loader will get tidied up.
Then the base display needs a tidy up and rejigged
Dragged the display base out, it’s my old go to generic one I did years ago. Still works ok and with a bit a TLC will bring it back to life.
Made the main start on the commander…
Collar tabs, sleeve eagle, cuff band (Das Reich) are on.
I need to double check the collar rank against the shoulder boards and see if they are black with pink edging or silver with pink edging… I can’t remember about the collar tabs … were the non edged black ones NCOs and the white edged ones officers ? Will try and look it up tomorrow…
The decals are the Archer dry set. I will be using a German generic number set I came across for the turret rear bin, so that was a bonus.
In fact I may need to do the SS one again as it slipped down slightly and only just noticed it, and it has a white edge as to the rank one doesn’t… Will need to check that tomorrow
Those figure decals look fantastic John. The perfect ending to trim out your Tiger. It looks stunning now - can’t wait to see it done.
