I have continued work on my M270A1 MLRS undergoing maintenance. I started it over on the old forums and you can see the earlier progress here: XXX (Which no longer works.)
Here is the build at Fine Scale Modeler to see the first half:
After a couple week break where I took an early trip to go meet my first grand daughter (she came a few weeks early and mom and she are doing wonderful), I am back at it.
I have painted all the parts in NATO camo and marked it as launcher C-22 from 6-37 FA (MLRS), 2ID in S. Korea. I made the decals myself, including the Asian Royal Lions on the front of the cab, from home printer decal paper.
I added the A/C unit, APU, and MG mount from the Dragon M270A1 to bring it up to pretty current standards, about late 2015-early 2016 based on Load Test date of 23 OCT 15 on the side of the LLM.
I also added Combat ID Panels (CIPs) to the sides and front.
The doors and side engine access panel.
Next up is tracks, final assembly and a light weathering. More to come soon.
The M270A1 MLRS Launcher is complete. I weathered it with a couple washes of a dirt brown color and a lighter sand color to give it a well-maintained, slightly dirty look, as you find vehicles in the motor pool.
You can see below that I added the steering linkage from the steering parts under the cab to the transaxle. I also connected the wiring harness to the cab underside.
I highlighted the interior of the LLM with a bit of aluminum to bring out the details. I also blackened the face of the LLM to represent the charring that occurs as the rockets are fired.
Thanks guys. It was a fun build. I really like how it turned out, esp. the engine compartment area.
No, both the MLRS Bns I served in (1-21 FA, 1CAV and 1-39 FA, 3ID) were all sand. I was stationed in Korea in an M109A6 Paladin Bn, where I saw these and had a buddy in 6-37 FA (MLRS) at the time. I already have a launcher from each of the Bns I was in and wanted one in camo this time. This seems to fit the bill just fine.
Interesante transformación. Estoy con un m270 de Dragón del año 3 antes de Cristo y quiero llevarlo a la versión A1. Podrias facilitarme las medidas del aparato de aire acondicionado y las cajas del gas Halón? Enhorabuena de nuevo
By deduction I can come to think that in the case of the m270 it may be a light green. Identical or similar to the interior of a m113. Tamiya’s XF-21 may be successful
